Precatalyst removal - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Precatalyst removal (/showthread.php?tid=19087) |
Precatalyst removal - Daniel306 - 23-11-2013 Getting this thing off was a real pain, can i cut it out and weld a pipe in or will it cause it to fail the mot? ![]() Should be Hdi section... RE: Precatalyst removal - cully - 23-11-2013 umm give us a clue what car it is? RE: Precatalyst removal - Daniel306 - 23-11-2013 Its a 307 hdi, this is in the incorrect section. this thing in between the Turbo and DPF filtter, service box says it a Precatalyst do i really need it or can i make it smaller/easier to fit? RE: Precatalyst removal - cully - 23-11-2013 is this the one with the pressure sensors befor and after as iff you remove it it will flag up a pollution fault i think it needs mapping out too RE: Precatalyst removal - Daniel306 - 23-11-2013 Is that not the Dpf? this has got a sensor before and there is a second sensor in the Dpf, you could be correct but i thought the one in the Dpf was a EGT sensor? http://www.citroenet.org.uk/passenger-cars/psa/c5/c5tech3.html |
