Can't tell if my suspension's standard, or something's wrong.
As stated in the title, there's around an inch (maybe slightly less) between my tire wall and the arch itself. The tyre specs are 195/45/15.
Bearing in mind an old woman has been the only owner before me. I can't think of many boy racer pensioners when it comes to mind.
I have an HDI D-Turbo, does this spec/trim have a lowered suspension as standard? I'm no expert on suspension, so could something potentially be wrong?
Your tyres are the wrong profile for a 306, so that will also be making it a little lower than it would be as standard. Also D-Turbo spec is slightly lower over a base spec model. Put up a photo, that's the easiest way for us to say.
Yeah I thought that, profile's meant to be 55 isn't it?
Not able to put a photo up, iPhone gave up on me a while back and stuck with an absolute heap of a phone. Great!
Yes but i would go for 50's
Mine is on standard HDI Dturbo setup.
Does yours look like this or lower?
[Image: IMG-20121118-00457.jpg]
I'd say it's been lowered. The smaller profile will make the car sit lower, but the distance between the centre of the wheel and the wing will remain the same so the smaller profile will create a larger arch gap, just under 1cm more between the top of the tyre and wing.
Yeah DeeTurbo, it'd be slightly lower. I'm not complaining really; it's at a nice height and there's no reverse rake unlike the boy's from Magherfelt just up the road Tongue
Also, nice HDI, almost identical!
  206 suspension users? Rock hard suspension HDIkyle 10 8,129 10-05-2013, 05:29 PM
Last Post: puglove
