Td04 air filter
Td04 air filter
How do people route there filters? I do have a zantia pipe but it hits the brake res so I'm considering removing the brake res bottle to allow it to fit. But how do others go about it?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
De filter ftw
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
flexi pipe.
/pearoast
I have been running no filter but be nice to least something there. Even a cone straight onto inlet. Will see what room there is behind wing or in arch
Blaze 1.6 Dead
Cheapo airfilter off eBay works well with me mate.
About £10 posted
Get a reducer elbow in silicon, a joiner and some flexi pipe going to the filter
I've tried and failed many times to try and get something sorted!
Only way I reckon is to have 90 off turbo, up over cambelt and then across.
(04-11-2013, 07:30 PM)c.gerrard Wrote: I've tried and failed many times to try and get something sorted!
Flexi pipe mate as said above. I think it was Padge who had a neat setup on his old diablo
HDi Cabby Project Click
As in routed the way I said?
There's no way it will go behind the block with my IC piping.
(04-11-2013, 08:21 PM)c.gerrard Wrote: As in routed the way I said?
What about how I got mine done?
There is quite literally no room. You've got a turbo with more room I'm assuming.
The only way it will fit, is if its crushed, so there's no point in having it.
Is there no room at all for some flexi to come up between the strut tower and master cylinder?
Otherwise why don't people mount their turbos the other way around down the back with the inlet facing the gearbox? (obviously no good on a tmic but front mount should be fine)
(04-11-2013, 08:37 PM)c.gerrard Wrote: There is quite literally no room. You've got a turbo with more room I'm assuming.
Yeah must do but the flexi pipe is very tight between the brake servo and inlet manifold
If I didn't have the ECU to worry about things would be so much simpler. I ran defiltered for a bit, wasn't happy and had to fit a filter. Standard one won't fit me, so had to think around the box....
So for my sins I use this rather quare setup
[Image: Image882.jpg]
It actually works rather well despite it's clumsy appearance and proximity to the rad. Breather was later engineered into the pipework rather than poisoning me!
[Image: Image423_zps1ac08bc4-1_zps15c76431.jpg]
[Image: 483801_10151793021340620_1658020522_n_zps665733c0.jpg]
Might have to put gas struts on my 205 bonnet to get rid of the hinge.
Would make routing the air filter 10 times easier
in that picture padge it seems you have loads of room between the expansion bottle and the fuel pump i know mine is a lucas but would changing to a bosch open that space up or have you done something else?
Td04 and a Lucas? Can't be a happy marriage surely?
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
(05-11-2013, 06:55 AM)Paul_13 Wrote: Might have to put gas struts on my 205 bonnet to get rid of the hinge.
Remove the original one and keep it in the boot, its only two m6 nuts and how often do you use it?
Padge what size pipe is that on your airfilter? Did it work well?
It's French so a lot!
My luck is I'll lose it haha
I've got some clips I cut off a shell when I was going to fit struts to my ph1 if your interested?
I just run de filter loads easier
Team Doesn't own a 306
2.25"
(05-11-2013, 07:08 PM)306pc Wrote: Td04 and a Lucas? Can't be a happy marriage surely?
My 205 loves it. Heart
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
