Xud and Hdi Sumps
Xud and Hdi Sumps
As above are they the same? Can't get on to service box to have a look
no mate
00' 106 Indy - Moonstone - Sold
97' 106 XT 1.6 - Mayerling Green - Swapped
95' 306 P1 DT - Onyx - Scrapped
97' 306 P2 DT - Silver - Scrapped
97' 306 P2 DT - Onyx - SORN awaiting scrap
Alright thanks for that
Hdi is ally and XUD is steel. Steel is better because it doesn't crack when a peanut hits it.
The sumps are all the same fitment wise, you can fit a hdi sump to an xud and an xud sump to a hdi.
Like facial hair said, one is steel and the other Ali
If you try and fit an Ali sump to an xud without aircon and power steering at the bottom then you will have to cut the aircon mounts off the Ali sump for them to fit
And obviously if you have air con you won't be able to fit a steel sump as the brackets aren't there
alloy sump holds more oil Wink
Thanks everyone, someone wants to put an xud sump onto a hdi engine. Don't know if it has aircon or not but will find out, if it does is the bracket an important one?
the aircon pump uses the bracket as supports
if you remove this you will have to change the aux belt length and reroute it Wink
Xud use Ali also all aircon models do
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
  Sumps XUD7 / XUD9 ginge191 7 4,823 04-08-2016, 05:28 PM
Last Post: Danny Wideboy
  sumps.... ozonehostile 11 6,690 08-12-2012, 03:50 PM
Last Post: ozonehostile
