swapping gti6 engine
Just want to know if the gti6 engine and gearbox will fit in a mg zr? As might be selling engine to cousin for his track car Smile comments appreciated thanks!
 Black 306 1.9 dturbo PH1 - on going project
Moonstone 306 GTI6 PH2 - Stripped and Scrapped
Honda Civic EP3 preface lift type R - Write off/Stripped and scrapped
Diablo 306 1.9 dturbo PH3 - Scrapped
Honda Civic EP3 facelift type R - daily
Anything would with enough time and money.. but it's not a straight fit..
You would need new engine mounting points welding in, either adapting the chassis to fit a 306 subframe, or adjusting the existing drivetrain to fit the '6 lump.
Not an easy task however you look at it
Ok thanks guys! Smile
The driveshafts will need modifying, also on the mg the exhaust manifold is at the front of the engine so on a 6 engine you will probably have to cut a tunnel in the bulkhead to run the exhaust down the back
Or get really clever, take the gearbox apart, reverse the internals and mount the engine 180 degrees around.
Failing that, retrofit the MG Box to the '6 engine. I have no idea what the engine bay of the MG looks like so I'm firing in the dark here! lol
Way more work than it would be worth imo. Surely some kind of turbo'd rover lump would be alot easier?!
Rover Turbo V8 did I hear?!
V8 twin turbo anyone!
Remember that the MG ZR was designed for a super light ally block 1.8 weighing sub 100kg... A GTi6 is a iron block 2.0, canted back with hefty 6 speed gearbox.
TBF in terms of engine designs, you couldn't really get much different! The only real similarities are that the're both 4 cylinder 16vs....
Cheers everyone, loads of help! Think he's looking at 2.5 v6 engine now Smile
*2.5 v6 zs engine
Why? Just slap a rover v8 in it. I would have thought it would be an easier job?
Or either that yes! Ill have a word with him tomorrow and see what he thinks to it, most likely he will want that! Haha :p
V8 would be win. Friend of mine just put one in an old rx7!
it's still a rover though Doh
00' 106 Indy - Moonstone - Sold
97' 106 XT 1.6 - Mayerling Green - Swapped
95' 306 P1 DT - Onyx - Scrapped
97' 306 P2 DT - Silver - Scrapped
97' 306 P2 DT - Onyx - SORN awaiting scrap
id just leave the vvc running gear in the posh 25
I would stay well away from the V6 K6 lump, it suffers like all other K series S**T with the god ol headgasket.
Maybe think about the Rover 2.0 Turbo engine that was fitted to the 200 Tomcat, there are a few on EBay
1999 2.0 8v Turbo 306
You Tube: 832 Performance
v6 k6 lump is very expensive to fix let alone do a belt on one!
better off as mentioned T series the car or leave it be, as rover modifing is a bit of a f*ck on, trust me on that one.
(14-10-2013, 11:38 AM)BenDturbo1 Wrote: Just want to know if the gti6 engine and gearbox will fit in a mg zr? As might be selling engine to cousin for his track car Smile comments appreciated thanks!
Your 'cousin' isn't lolsteve, is he?
This is his plan to 'beat a GTi-6' eh?
lol
[Image: MIRKxNP.jpg]
Go for the T16 it's a far better swop that's what I got in my zr Wink
lol
No its not haha I don't know what he's thinking of putting in it now he changes his mind every day lol
  306 S16 engine with GTi6 inlet Pingaz 6 6,367 14-05-2020, 08:21 PM
Last Post: Pingaz
  Xud to gti6 engine Chris_90 7 5,959 26-07-2017, 03:52 PM
Last Post: fatlapit
  GTI6 engine tune KevinTW 7 6,349 16-03-2017, 11:51 AM
Last Post: KevinTW
