abs
abs
Hi I have a 99 306 hdi, the abs light is on. I have tried scanning fault
With pp2000 but it wont read the ecu, the sensors are fine, and fuses look
Fine. What chances of it being abs ecu broken.
Thanks
Not being running but you say you tried scanning for faults but it wouldn't read the ECU so how do you know the ABS sensors are ok?
A garage tested the sensors using multimeter and I tested them after reading
How todo it on here to double check.
