abs - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: abs (/showthread.php?tid=17797) |
abs - kris_taylor1988 - 04-10-2013 Hi I have a 99 306 hdi, the abs light is on. I have tried scanning fault With pp2000 but it wont read the ecu, the sensors are fine, and fuses look Fine. What chances of it being abs ecu broken. Thanks RE: abs - Frosty - 04-10-2013 Not being running but you say you tried scanning for faults but it wouldn't read the ECU so how do you know the ABS sensors are ok? RE: abs - kris_taylor1988 - 04-10-2013 A garage tested the sensors using multimeter and I tested them after reading How todo it on here to double check. |
