Threads: 374
38
Car Model/Spec: GTI 6
On m27.
All temps were fine, went to over take and BOOM, clackity clattery followed by a small amount of white smoke, ZERO power, still turns on/tuns over with the same clattery noise.
Answers on a postcard.
Gutted
Threads: 34
8
Given 8 thank(s) in 8 post(s)
Defo timing.. slipped a tooth
Threads: 169
91
Given 1 thank(s) in 1 post(s)
This is in the 205?
Threads: 374
38
(04-10-2013, 07:25 AM)Seb_Ryan Wrote: Defo timing.. slipped a tooth
Really?
I wouldn't have pointed at that; I was midflow on the motorway?
And yeh grant, the 205
Threads: 169
91
Bad times dude
Threads: 34
8
Belts can go at any time.. honestly thats what it sounds like.. I wouldn't keep starting it just incase.. check timing first.
I had a belt slip twice on my pug in 2 weeks (dodgy aux belt tensioner) belt off.. timed up, belt on and it ran fine lol
Threads: 374
38
Interesting. Sounded a hell of a lot worse
But seeing as it did still run for a bit, I switched off as soon as possible; it did start again, don't sound bad until I blipped the fuel. Then shut it off again.
I'll check the belt when I get off the motorway
Threads: 163
53
Car Model/Spec: 406 HDI
99% sure it's a slipped belt. To be fair, it happened to me on my sigma DT, sounded awful, really thought I'd smashed some valves. Timed it up and besides a little top-end rattle it was fine...
Threads: 289
92
Car Model/Spec: Phase 17 R26
Ah shit that's unlucky mate. Hopefully it's nothing too major
Threads: 374
38
On tow; we had a look at belt, he doesn't agree as it's pretty tight still.
Hummn
Threads: 34
8
04-10-2013, 09:08 AM
(This post was last modified: 04-10-2013, 09:09 AM by Seb_Ryan.)
(04-10-2013, 09:04 AM)ginge191 Wrote: On tow; we had a look at belt, he doesn't agree as it's pretty tight still.
Hummn
It will still be tight between all sets of pulleys apart from one.. so could be at the water pump its loose etc. If that makes sense
Threads: 39
4
Car Model/Spec: P2 Dturbo
sorry I didnt stop ginge only realised it was you when it was to late lol hope you get it all sorted
00' 106 Indy - Moonstone - Sold
97' 106 XT 1.6 - Mayerling Green - Swapped
95' 306 P1 DT - Onyx - Scrapped
97' 306 P2 DT - Silver - Scrapped
97' 306 P2 DT - Onyx - SORN awaiting scrap
Threads: 476
81
Car Model/Spec: 306 Rallye
Threads: 90
54
Does it motor full full compression or sound more smooth than normal? Is aux belt still on?
Belt dosnt normally slip unless the aux belt fails or something drops in there, aer covers on? has nut on tensioner fallen off?
Either way, if its slipped it will still be tight it just slips around the crank a couple teeth if a foriegn object gets in there.
Sure its not just a more minor issue? get avideo tbh.
Threads: 374
38
(04-10-2013, 09:22 AM)darrenjlobb Wrote: Does it motor full full compression or sound more smooth than normal? Is aux belt still on?
It idles rough, spluttery, but it idles itself. Then when throttle is added you get the bashing of nails.
The only cover which is NOT on is the pump cover. And the aux belt is 205 aux setup (just alternator) thin belt, will double check to see its still there; pretty sure it is; no battery light come on when it was still running as I made my way across the motorway
I'll have a thorough look tomorrow when it's dry and I have time. I'll video if/when I redo the belt and check over nuts and bolts
Threads: 117
119
Threads: 29
18
Car Model/Spec: mx5 mk1 1.8
(04-10-2013, 10:47 AM)Poodle Wrote: GINGIVITIS!!
YOU JUST TOOK THE WORDS FROM MY BRAIN!
I was 'totes going to say this.
I'm glad you did though; I don't fancy a brick to the face from Le Ginge...
Threads: 130
82
Car Model/Spec: 106 GO-NAD
I wouldn't worry abiut bricks from the ginger, they burn up when leaving his atmosphere.
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
Unlucky man..
What turbos on there atm?
Threads: 374
38
(04-10-2013, 11:55 AM)silverzx Wrote: Unlucky man..
Still T2 - TD25 is prepped for welding
Threads: 63
26
Car Model/Spec: GTi6
Don't panic - I'll be over with an assortment of hammers
Threads: 591
54
sounds like its out of time to me.
belt cover off, on motorway, bit of grit, shlam.
bugger though still mate, hope sorted soon.
/brokexudfwends
Threads: 541
124
Dropped a precup or maybe a valve
Dont worry about fixing it, itll only be something simple, just fir a 2.1TD or better a 2.5TD
Threads: 202
58
(04-10-2013, 03:23 PM)Dum-Dum Wrote: Dropped a precup or maybe a valve
Babe, as much as I love you, give it a rest with the old displacement thingy. Please? xx
Threads: 581
195
(04-10-2013, 11:03 AM)MissTap_GTI6 Wrote: I'm glad you did though; I don't fancy a brick to the face from Le Ginge...
Ginge A.K.A Chris Brown?
Threads: 29
18
(04-10-2013, 07:17 PM)Niall Wrote: (04-10-2013, 11:03 AM)MissTap_GTI6 Wrote: I'm glad you did though; I don't fancy a brick to the face from Le Ginge...
Chris Orange
Threads: 591
54
Threads: 63
26
(04-10-2013, 09:33 PM)Piggy Wrote: so...whats happening..?
Beer is fixing the crisis, don't worry
Threads: 29
18
from ginge as he's drowned his sorrows and on this account; going to go over it tomorrow, check timing and as darren said, tensioner bolts etc, see if i can find anything wrong there..
then go from there
Threads: 541
124
(04-10-2013, 07:12 PM)Jonny81191 Wrote: (04-10-2013, 03:23 PM)Dum-Dum Wrote: Dropped a precup or maybe a valve
No
