Threads: 96
7
Car Model/Spec: 306 tractor
28-09-2013, 11:19 PM
(This post was last modified: 07-10-2013, 04:39 PM by devils_fuel.)
I'm looking at getting a Bosch set up for the XUD, what do I need to do this from a Lucas and is there anything I need to ask/check as I've never bought one before
Threads: 132
4
You want one that's been sat full of diesel
Full set of Bosch injectors
Bosch lines
New leak of pipes
While doing it may as well do timing belt an that.
Threads: 96
7
(28-09-2013, 11:24 PM)Tyronnster Wrote: You want one that's been sat full of diesel
Bosch lines
New leak of pipes
Ok, so is the set up you mentioned on another thread full of fuel?
Threads: 226
24
Car Model/Spec: A3 TDi
The fuel inlet for the bosch would be handy aswell, piece of tube that goes round the back of the pump that you clamp your hose onto.
Threads: 96
7
Does a Bosch pump actually give more proven mpg or is it an urban myth?
Threads: 343
15
Car Model/Spec: 106 gti / 306 hdi estate
Given 3 thank(s) in 3 post(s)
(29-09-2013, 12:12 AM)devils_fuel Wrote: Does a Bosch pump actually give more proven mpg or is it an urban myth?
I noticed mine was quieter with the bosch than lucus on my old d turbo, Not sure about mpg tho cos soon as i put it on, i put veg oil in  but you will be saving money on veg oil if your gonna run it
Threads: 39
4
Car Model/Spec: P2 Dturbo
Don't forget the woodruff key
00' 106 Indy - Moonstone - Sold
97' 106 XT 1.6 - Mayerling Green - Swapped
95' 306 P1 DT - Onyx - Scrapped
97' 306 P2 DT - Silver - Scrapped
97' 306 P2 DT - Onyx - SORN awaiting scrap
Threads: 96
7
29-09-2013, 10:07 AM
(This post was last modified: 29-09-2013, 10:11 AM by devils_fuel.)
(29-09-2013, 06:55 AM)Chris_90 Wrote: I noticed mine was quieter with the bosch than lucus on my old d turbo
Is it??
(29-09-2013, 08:46 AM)adamm306 Wrote: Don't forget the woodruff key
Guess I need a pulley as well?
God this kit is going to cost dollar...
So how much should I budget for the kit?
Threads: 226
24
Noisy as f*ck if you use lucas injectors, I paid about 100 for my first setup and 80 total for one i bought other day! Shouldnt be to bad!
Threads: 39
4
(29-09-2013, 10:07 AM)devils_fuel Wrote: Guess I need a pulley as well?
yeah
Threads: 343
15
It isn't expensive really £30 for Bosch pump lines and injectors about £10 (looms scrap yard prices) cambelt Kit was £40 and And about £15 for water pump. Then bit of fuel pipe £5 max all you need for £100, if your planning on running veg oil you will soon make your money back depending on how many miles you do
Threads: 96
7
Blimey, I never find setups that cheap when I have the cash lol
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
(29-09-2013, 10:39 PM)devils_fuel Wrote: Blimey, I never find setups that cheap when I have the cash lol
You see them pop up on here for under £90 fairly regularly.
I'm sure we'll find you one.
At last! How were you persuaded?
Threads: 96
7
(01-10-2013, 08:18 PM)silverzx Wrote: (29-09-2013, 10:39 PM)devils_fuel Wrote: Blimey, I never find setups that cheap when I have the cash lol
What a complete kit inc everything to replace it, pulley and woodruff key etc??
Wanna run it on veg due to fuel prices or maybe scrap it lol
Threads: 266
18
(01-10-2013, 08:26 PM)devils_fuel Wrote: (01-10-2013, 08:18 PM)silverzx Wrote: (29-09-2013, 10:39 PM)devils_fuel Wrote: Blimey, I never find setups that cheap when I have the cash lol
Yeah, again you might find one in a scrappy even cheaper!
Threads: 96
7
If you see one cheap like the budgie...grab it
Threads: 266
18
Theres an 11mm for £100 on here.
Might as well do it properly?
Threads: 96
7
Ha ha but that's just for the pump plus it would drown my car in fuel, only got a kk..I think
Threads: 266
18
(01-10-2013, 09:36 PM)devils_fuel Wrote: Ha ha but that's just for the pump plus it would drown my car in fuel, only got a kk..I think
Thats kind of the point...!
Threads: 36
2
Car Model/Spec: PH2 Dturbo
If you can get the 11mm I would go for it. Thats my next step.
Threads: 96
7
(01-10-2013, 09:50 PM)silverzx Wrote: (01-10-2013, 09:36 PM)devils_fuel Wrote: Ha ha but that's just for the pump plus it would drown my car in fuel, only got a kk..I think
Ha ha I can't be bothered with fast cars etc, if I wanted a fast car I'd get a Perv turbo, just happy chugging along in my derv thinking about the money I'm saving...so opposite of Jeremy Clarkson
Hence I want it to run veg
Threads: 198
135
Nah it wouldn't. VW's have used 10mm pumps on their NADs, no reason why an 11mm would drown a DT. You don't HAVE to run full fuelling on them. Yeah you'll get more off boost smoke but control that with your right foot. Simple.
Plus you have the potential for epical power as and when you find a blower you want.
Threads: 163
53
Car Model/Spec: 406 HDI
I'm not sure about the MPG thing, but every XUD I've had with a Bosch has been slightly better on fuel, although that's always been veg oil. Maybe it's veg oil that gives better MPG?
Threads: 92
43
Given 2 thank(s) in 2 post(s)
No veg gives worse fuel economy, but because its so much cheaper to buy, it gives you better pence per litre
Threads: 163
53
(02-10-2013, 08:09 AM)Connor Wrote: No veg gives worse fuel economy, but because its so much cheaper to buy, it gives you better pence per litre
Thing is I've measured it mate, 450 to a tank on derv, 470-480 on veg? A few tanks have given that result with pretty much the same driving...
Threads: 591
54
depends hugely on what diesel used and what type of veg used.
Threads: 163
53
Shell Fuelsave vs KTC Cooking oil (soya crap) with 10% Shell Fuelsave. Loads more power on derv though, wish Costco still did rapeseed.
Threads: 266
18
Definately a power difference in the higher RPM's.
If you had a more suitable spooler like a VNT or GT then I can't imagine there being an awful lot of difference?
Threads: 198
135
(02-10-2013, 10:17 AM)silverzx Wrote: Definately a power difference in the higher RPM's.
There is, complete lack of top end, spools quickly but completely flattens off from 3.5k+
Threads: 163
53
(02-10-2013, 11:37 AM)cwspellowe Wrote: (02-10-2013, 10:17 AM)silverzx Wrote: Definately a power difference in the higher RPM's.
This, that's exactly my problem. A little derv improves it, but it's still not there...
