water in l/h side oh boot?
i keep getting a little ater in my ph1 l/h side of my boot by the lense corner. the lense seems tight and sealed any ideas?
[Image: cornishmafia.jpg]
Behind the carpet on the wheel arch there are two holes which should have covers on check they are there.
Also check to see if there is anything behind the covers as this stops water coming up from wheel spray.
found it it was the l/h lense seal
Its a common thing to drill two holes in the bottom of the light unit Smile
  Side skirt extensions and rear diffuser side pieces Slam Wagon 38 18,667 19-11-2014, 05:56 PM
Last Post: welshpug
  Water leaking into the boot thought it was the light but it's not any ideas? titch 20 10,063 23-02-2014, 03:20 PM
Last Post: titch
  Water leaking into boot titch 11 7,162 02-01-2013, 04:34 PM
Last Post: titch
