17-09-2013, 03:46 PM
Does anyone no if the sump off an 1800 16v 306 will fit my hdi.
Its alloy like the hdi one and has the mounts for aircon on it.
Cheers
Cheers
Sump Swap
Its alloy like the hdi one and has the mounts for aircon on it. Cheers
17-09-2013, 04:50 PM
17-09-2013, 04:59 PM
coz one is a 1.8 sump and one is a hdi sump.
different block, different sump. Wishes for more power...
17-09-2013, 05:08 PM
Yeah different blocks but I think you would find it surprising how much of the stuff from different engines bolt on. There's a lot of gearboxes on 306s that bolt onto other engines etc.
A lot of the blocks have the same design on the bottom for the sump. I do need to check to see if it looks the same but the best answer to the question would be someone who has tried it
17-09-2013, 05:15 PM
(17-09-2013, 03:54 PM)Piggy Wrote: er no. Your arrogance has no end! How can you answer without knowing the facts. Frosty I had a look at work earlier cant see why it shouldn't. Looks same apart from drain plug on opposite sides. As long as all the holes line up should be ok
17-09-2013, 05:17 PM
Yeah I will have a look with it up against the hdi engine Gary has.
17-09-2013, 05:18 PM
Your ignorance of my knowledge also knows no ends.
17-09-2013, 05:23 PM
(17-09-2013, 05:18 PM)Piggy Wrote: Your ignorance of my knowledge also knows no ends. Who knows u may be correct if so ill rep you However the way you put your answers accross is arrogant for sure. But thanks for the help ;-)
17-09-2013, 07:17 PM
(17-09-2013, 05:18 PM)Piggy Wrote: Your ignorance of my knowledge also knows no ends. I wouldn't call your previous comment knowledge! All you have stated is that 1 is a 1.8 sump and the other is a hdi sump which come off different blocks. That is pretty obvious and was the question asked in the 1st place. But like you jimbo said if your right fair play
17-09-2013, 08:35 PM
That's like saying a gti sump won't fit a Xud. But there both Xu blocks
TD04 11mm Sedan, now 2.1 vnt
Sedan Project http://306oc.co.uk/forum/thread-5763.html Provence Dturbo Dead Blaze 1.6 Dead China 5dr '6 Death by cambelt failure Matt White HDI estate Death by wiring Sedan Dturbo aka triggers broom Diablo estate Dturbo Living dead
17-09-2013, 08:44 PM
A HDi is a DW block...
I'm pretty sure it's the same sump tbh though...check servicebox, its probably even the same part number.... |
