09-09-2013, 09:32 PM
2001 306 how to adjust hand brake ?
how to adjust handbrake ?
09-09-2013, 09:46 PM
unsrew the 2 torx bits in under the rear ashtray pull off gearstick be careful not to hit yourself in the face unclip gaitor and remove centre console bit
take handbrake off and adjust the nut on the long thread clockwise
00' 106 Indy - Moonstone - Sold
97' 106 XT 1.6 - Mayerling Green - Swapped 95' 306 P1 DT - Onyx - Scrapped 97' 306 P2 DT - Silver - Scrapped 97' 306 P2 DT - Onyx - SORN awaiting scrap
09-09-2013, 11:12 PM
(This post was last modified: 09-09-2013, 11:14 PM by pugjohn306.)
Is it maxing out mate if it is no amout of adjusting the cables by the handbreak leaver are gunna do anything apart from stretch the cables but if its abit sloppy then yes as above but if i were you id check the adjusters in the drum(i take it you have drum) if not i typed this for nothing lol...
(09-09-2013, 09:46 PM)adamm306 Wrote: unsrew the 2 torx bits in under the rear ashtray pull off gearstick be careful not to hit yourself in the face unclip gaitor and remove centre console bit You dont have to take gear knob off i asume thats what you mean by gearstick lol pop off the retaining bracket it will fit through the hole in the center parting without removing gear knob..
(msg sent from hell)
10-09-2013, 06:28 AM
yeah you can just lift the rear of the centre console after removing the screws and wedge it up then extension plus 12mm deep socket. or 13mm!
but is this discs or drums at rear?...if drums, you want to adjust at the drums first then just take slack up with the internal adjuster Wishes for more power...
10-09-2013, 09:57 AM
(10-09-2013, 06:28 AM)Piggy Wrote: yeah you can just lift the rear of the centre console after removing the screws and wedge it up then extension plus 12mm deep socket. or 13mm! Lol i swear thats what i just said lol...
If i dont c ya threw week ill c ya threw window. |
How to adjust coilovers? | kentiiboii | 38 | 6,505 |
19-04-2012, 03:03 PM Last Post: kentiiboii |
How do you adjust the handbrake on a 306? | Welshy_Pete | 7 | 5,006 |
06-02-2012, 08:46 AM Last Post: mark_airey |
