Threads: 169
91
Given 1 thank(s) in 1 post(s)
(03-09-2013, 11:26 AM)Dum-Dum Wrote: Gear stick extension? Already got one of those. But sod making it from 30mm dia ally bar haha. Would weigh approximately 7.5 f*ck tons
(03-09-2013, 11:34 AM)Ed Doe Wrote: Solid top engine mount?
Or solid bottom mount (dunno why you'd want that though given you've already got one...)
Close. Don't know how you could make a solid upper mount from that? But its to replace the bush that goes in the lower engine mount fork.
Cut it into 30mm lengths and drill a 12mm hole though it and hey presto, just press it in.
Goodbye fillings/spine
Threads: 138
72
Car Model/Spec: Mincebus
ROFL! I want a go!
Astor 'X' 4 GTi6- 6 - SOLD!
Threads: 169
91
I bet your girlfriend would too. Probably beats the washing machine!
 I jest
Threads: 138
72
Threads: 169
91
Busy day at work then ed? Lol
Threads: 138
72
Yup.
I'm on lunch in fairness
Threads: 541
124
Grant Yessssssssss, I should of thought of that after having sent you the measurements of the oem bush the other week.
Threads: 169
91
Thats it Chris!
So it started life like this
And got cut to 50mm (near enough!)
And drilled out to 10mm. The old bush had to be drifted out (absolute bitch of a job)
And this is what remains
And how it sits tonight. Still gotta drift it through another ~15mm
Took the best part of about 4 hours. Well, managed to fit new rear discs and pads, but that takes about as long as a cup of tea!
Threads: 226
24
Car Model/Spec: A3 TDi
Thats going to be umm, interesting.
Threads: 169
91
No more interesting than the billet mount that's already in the lower engine mount lol
Threads: 169
91
So a bit of an update.
Managed to get the lower engine mount fork billet bush pressed it properly.
Jesus christ, the throttle response is immense! It really has livened up the car no end. The responsiveness, feedback and sharpness is phenomenal.
Its not all bliss though. Its madly solid, to the point it reverberates every panel in the car. The panel vibration is louder than the exhaust
However, the girlfriend loved it, I near enough had to bail out the car 500 meters up the road. Winnar
Had a productive day at work friday... Somehow I am now particularly popular amongst traffic wardens in london nowdays...
And went to the breakers yard today. Got a good bargain. EPAS pump, new gear stick, lower engine mount fork (with standard bush!!!) and this battery box for £40
A little surface rust, but been grinding it back this eve and ready to paint up now
Threads: 169
91
So first update in a while. Been very quiet due to various social matters and a lack if spare time. Managed to get out on the car today and get quite a bit done.
Firstly I set about chopping the suspension turrets so that I can run camber on my adjustable top mounts. As you can see from the picture, the adjustment is hindered by the shape of the turret, so some modification is needed
Like so:
Also sanded down some surface rust whilst I was there
All primered up
And in its full colours
Got quite a bit of the inner arch undersealed too. Also unblocked the drainage point by the wiper motor
Before:
After:
Threads: 130
82
Car Model/Spec: 106 GO-NAD
You seem to have a bit of lady garden stuck in your chassis....
Threads: 541
124
Those rain gutters are a terrible design. Really need to try and clean mine.
Threads: 169
91
24-09-2013, 10:10 AM
(This post was last modified: 24-09-2013, 10:11 AM by Grant.)
It really is a poor design. You could cut the hole bigger if you really wanted. At least that way leaves would have half a chance of washing out...
I've also found a bit of rust that will need welding up under the PAS reservoir
Threads: 169
91
So got a lot of goodies to fit to the car now.
List to fit:
-'6 inlet manifold
-New wishbones
-New hubs
-Scorpion exhaust
-Side skirts
-New dent free door
-New dent free wing
-Black bonnet badge
-Non leaky door seal
-Arch liners - at last!
I also started rolling the arches to solve scrubbing issues on the rear wheels. Didnt go too well
excuse the crappy phone pic
Threads: 142
58
Car Model/Spec: E46 BMW 320d
I didnt realise Stevie Wonder did arch rolling!
Threads: 27
20
Kin hell what was you using? A steam roller lol
Threads: 169
91
'C'mon guys dont be mean, it aint that bad for a first attempt...
Threads: 142
58
29-09-2013, 05:08 PM
(This post was last modified: 29-09-2013, 05:08 PM by WiNgNuTz.)
If you say so mate.
Maybe if you squint a bit from about 400 paces away....
Threads: 581
195
It does look really good in real life. Just a bad angle on the photo.....all of them.
Threads: 186
38
Car Model/Spec: MG ZR VVC
Given 21 thank(s) in 19 post(s)
Holly duck balls! what is that!
Threads: 31
4
Car Model/Spec: tu5 bitza/cherry dt
Given 5 thank(s) in 5 post(s)
I do hope your still fitting those arches, on another note what did you roll em with? A sledge hammer??
Threads: 169
91
Pliers lol
Threads: 27
20
Ha ha your fitting arches ain't ya??? I fecking hope so bud!! Lol
No way you would do that if your not!! I think (pray)
Threads: 169
91
Nah not bothering with arches. I'm hoping that it will all bash into shape with a rubber mallet.
Threads: 27
20
29-09-2013, 09:45 PM
(This post was last modified: 29-09-2013, 09:45 PM by Jonny b.)
Ha ha that's the 6 ain't ιt!!!!
Calling troll!!!! Lol
Threads: 142
58
29-09-2013, 10:27 PM
(This post was last modified: 29-09-2013, 10:28 PM by WiNgNuTz.)
(29-09-2013, 09:45 PM)Jonny b Wrote: Ha ha that's the 6 ain't ιt!!!!
Good shout, but what about the grey door in the last pic?
Threads: 27
20
He said earlier dent free door dent free wing!!!
Threads: 541
124
Dude you need to get some stick on arches to hide that atrocity, Thats worse than my attempt to flare the front arches on my beemer by nearly 2 inches
