Wanted: XUD Head
Anyone have one in a reasonable condiiton; preferably skimmed and ready to fit.
I have one not skimmed!!?
Ginge, just buy a head and get it skimmed?
And who's engine is fubard now?!?!?!
(04-09-2013, 09:11 AM)Ed Doe Wrote: Ginge, just buy a head and get it skimmed?
The time and effort to get a head from the scrappy.... nearly lost my rag gettin an inlet off yesterday as they drop these cars on subframes and really gets me wound up! Trying to get to the back of a bay to access the manifolds is a right PITA.
Early signs on the 205 Undecided It keeps temps fine, heats fine, doesn't over heat or anything, but it loses about 1.5L a fortnight, early foam stage in the rad/tank.
It'll make it through the winter i'd say, given it's driven sensibly Blush
ginge...you at castle combe on the 14th?
£15 for the effort of me taking it off and its yours
(04-09-2013, 09:16 AM)ginge191 Wrote: The time and effort to get a head from the scrappy.... nearly lost my rag gettin an inlet off yesterday as they drop these cars on subframes and really gets me wound up! Trying to get to the back of a bay to access the manifolds is a right PITA.
Fair enough!
Are you SURE it's going though. You say it's losing 1.5l a fortnight, is it a leak in the rad? Could be a small one only visible when the coolant system is under pressure? I know the nad had a leaky rad...
Foam isn't a biggie, I've had a bit of foam before, i'd personally not worry about it too much....
(04-09-2013, 09:44 AM)Ed Doe Wrote: Fair enough!
The coolant system has been an absoloute PITA since it got fitted and i've fixed numerous leaks across the car. But i tend to check after i drive/park/pullaway for any wet on the floor, and fail to see anything.. i know not a failsafe method, but nothing.
Yeh i was merely going to get one in case something went and i needed to change it quickly Undecided I'll keep a close eye on it..
(04-09-2013, 09:42 AM)Piggy Wrote: ginge...you at castle combe on the 14th?
Not sure if i am or not, should be... I'll let you know, thanks mate ThumbsUp
let me know by monday...as car will be scrapped
If you want the one in my garage come grab it. Will need skimming but that's about it.
(04-09-2013, 11:09 AM)Pompey306mark Wrote: If you want the one in my garage come grab it. Will need skimming but that's about it.
Was this the one that kept blowing; or was the head not the issue in the end...?
also, how much has it already been skimmed?
This is the one off my first engine, so did not have head gasket issues and I guess has not been skimmed before.
Spot on mark.
I'll message you if/when I need it x
ginge iv got 2 ones already skimmed so just let me know if you need one desperatly Smile
Current cars
Subaru Impreza 2.0d - Daily
Awesome mate!
Shall do ThumbsUp
