27-08-2013, 03:48 PM
My fan belt is squealing, and it's very high pitched, I was wondering if there is a quick fix until I can get it looked at.
Fan Belt Squeal!
27-08-2013, 03:58 PM
Tensioner needs to be tightened.
27-08-2013, 04:23 PM
There should be 2 cm of movement under firm thumb pressure. They do have to go quite tight to stop the noise.
27-08-2013, 04:51 PM
Bar of soap? Wd40 or the likes? That'll shut it up for a bit!
27-08-2013, 04:54 PM
Always make sure you cant turn the belt more than half way round once fitted and tightened, that shows you enough tension has been applied.
| Massive belt squeal | Nathan1305 | 3 | 2,970 |
12-03-2015, 05:19 PM Last Post: Nathan1305 |
Belt slapping wildly - belt tensioned - pics added | ginge191 | 57 | 51,122 |
25-04-2013, 09:22 AM Last Post: Mattcheese31 |
