Threads: 141
35
(24-08-2013, 05:09 PM)Chris_90 Wrote: Surely that filter on the vacuume line would make the brakes not work right?
That's why I'm really confused by it. Can't think of any logical reason for it to be there Tbh
Threads: 343
15
Given 3 thank(s) in 3 post(s)
Do the brakes work ok?....... We'll guessing they do if it's just gone though mot ![Undecided Undecided](https://www.306oc.co.uk/forum/images/smilies/undecided.png) it is strange just take it off and block it off to be safe I think
Threads: 141
35
Yeah the brakes work ok, nothing spectacular though. Il try it without the breather when I fit the braided lines and 266mm brakes
Threads: 23
Car Model/Spec: High Boost Rallye
Looks like an Ecotek CB-26P
Threads: 208
60
Given 5 thank(s) in 5 post(s)
(24-08-2013, 04:51 PM)ozonehostile Wrote: Here is the trouble maker! ![[Image: 20130824_123432_zps2d2795f8.jpg]](http://i1310.photobucket.com/albums/s649/ozonehostile/20130824_123432_zps2d2795f8.jpg)
Proper job, loving your work there zak
Threads: 141
35
24-08-2013, 05:51 PM
(This post was last modified: 24-08-2013, 05:53 PM by ozonehostile.)
(24-08-2013, 05:45 PM)luke306rallye Wrote: Looks like an Ecotek CB-26P
Just had a quick Google. Guess that what it is then :-)
Repped
(24-08-2013, 05:47 PM)puglove Wrote: (24-08-2013, 04:51 PM)ozonehostile Wrote: Here is the trouble maker! ![[Image: 20130824_123432_zps2d2795f8.jpg]](http://i1310.photobucket.com/albums/s649/ozonehostile/20130824_123432_zps2d2795f8.jpg)
Proper job, loving your work there zak ![ThumbsUp ThumbsUp](https://www.306oc.co.uk/forum/images/smilies/legacy/Skype/yes.gif)
Haha cheers. If your going to blow a clutch up do it properly haha
Threads: 208
60
(24-08-2013, 05:51 PM)ozonehostile Wrote: Haha cheers. If your going to blow a clutch up do it properly haha
Exactly mate! no point in pussy footing around , go hard or go home
Threads: 96
7
Car Model/Spec: 306 tractor
God that clutch is fecked mate, never seen one that bad !!!
FairPlay for cracking on with it and not hanging about
Threads: 141
35
(24-08-2013, 05:59 PM)puglove Wrote: (24-08-2013, 05:51 PM)ozonehostile Wrote: Haha cheers. If your going to blow a clutch up do it properly haha
The new clutch is only a 180mm so I expect it will probably happen again soon. Next time il be replacing with a paddle clutch and a 1.6 flywheel
Threads: 541
124
I think that breather is a case of stupidity of the previous owner
Threads: 130
82
Car Model/Spec: 106 GO-NAD
Struggling to understand how that ecotech thing is meant to work...
is the idea that it holds the pressure and allows then then the engine to pull vacuum from atmosphere once brake servo up to pressure...stops it becoming a restriction?
Threads: 141
35
Yeah I'm pretty confused about how it works too :-\
sack it off and sell it on bummersOC for lots of boost funds
Threads: 141
35
(24-08-2013, 09:46 PM)Piggy Wrote: sack it off and sell it on bummersOC for lots of boost funds
I may have been offered a 300bhp dyno proven 106 turbo for a ridiculously low price today
just engine or whole thing?
Threads: 141
35
(24-08-2013, 09:52 PM)Piggy Wrote: just engine or whole thing?
whole car
oooooooooo
Threads: 96
7
(24-08-2013, 09:48 PM)ozonehostile Wrote: (24-08-2013, 09:46 PM)Piggy Wrote: sack it off and sell it on bummersOC for lots of boost funds
I may have been offered a 300bhp dyno proven 106 turbo for a ridiculously low price today ![ninja ninja](https://www.306oc.co.uk/forum/images/smilies/legacy/ninja.gif)
Do it...
Threads: 102
9
once all the running gear is sorted, are you going to track prep it?
Threads: 141
35
(26-08-2013, 12:27 PM)procta Wrote: once all the running gear is sorted, are you going to track prep it?
Yes :-) already been getting quotes on having a cage welded in
good lad. you know it makes sense. 150kg ish maybe a lot...but so worth it...esp if you end up with 300bhp!
Threads: 8
Car Model/Spec: 405 SRDT
Given 6 thank(s) in 6 post(s)
(26-08-2013, 12:29 PM)ozonehostile Wrote: (26-08-2013, 12:27 PM)procta Wrote: once all the running gear is sorted, are you going to track prep it?
Yes :-) already been getting quotes on having a cage welded in ![ninja ninja](https://www.306oc.co.uk/forum/images/smilies/legacy/ninja.gif)
Hi, I saw your thread on your sedan, looks like you're not having much luck lately!
Out of interest, what sort of money are you being quoted on the cage welding? Is it a pre-fab job with weld in mounts and the cage bolts in or a fully welded jobby?
I soooooooo need a decent MIG. I've done a couple in the past but no-where to do any work under cover at the mo.
A proper cage wouldnt be migged!
It would be TIG, so much stronger and doesnt warp the cage/car so much when being put in due to difference in heat
Threads: 8
(26-08-2013, 04:12 PM)Piggy Wrote: A proper cage wouldnt be migged! ![lol lol](https://www.306oc.co.uk/forum/images/smilies/legacy/lol.gif)
I did ask if it was a weld in cage with mounts :p No problem migging one of them.
You can weld pretty much anything you want with a MIG anyway if you know what you're doing and balance the welding. If the welds aren't too hot and penetration isn't a problem why should it be weaker?
I've welded ALL sorts of frames with a MIG and warping's never been a problem.
I wouldnt want my cage welded in with a mig. no thanks
Threads: 122
9
Given 7 thank(s) in 7 post(s)
Have you given up on the truck tub?
Threads: 141
35
(26-08-2013, 07:19 PM)Jimbo Wrote: Have you given up on the truck tub?
Nope, it's been moved to its new garage this month and il finally finish it. Just got a brake line to replace and put seats in pretty much. Few electric bits to sort too but nearly there
Threads: 110
20
(26-08-2013, 07:25 PM)ozonehostile Wrote: (26-08-2013, 07:19 PM)Jimbo Wrote: Have you given up on the truck tub?
Its about time you finished it! Mines going on the road on the 1st
Threads: 102
9
how easy are these cars to turbo? as the engine bay on these are like metros, every small.
