Threads: 3
Car Model/Spec: Looking to get pug t.d estate?
Can anyone tell me what colour and paint code it is?
Threads: 42
8
Car Model/Spec: bone rattler 306...
(21-08-2013, 09:59 PM)LJ_D Wrote: Can anyone tell me what colour and paint code it is?
Should be a color code under the bonnet on the passenger side
(msg sent from hell)
Threads: 3
Everyone said go for panel filter on my sdi and when I changed to a enclosed cone filter with open front (if you get me) was even better.
It's just had new clutch and pressure plate (peugeot original).
Threads: 208
60
Given 5 thank(s) in 5 post(s)
welcome.
yes the later meridians had bigger rear TBs & ARBs
you will need an uprated clutch friction & pressuer, unlesd you go for a limted torque then you will get away with a new valeo.
you will need to winde the boost up manually on the turbo via the waste gate arm. it can be controled with a MBC after that
Threads: 3
Ok cheers puglove. Damn I was hoping to be able to go all out with torque having a new clutch and pressure plate.
What's a safe amount the clutch can go Upto?
And the boost upping is that via actuator rod shortening?
Cheers.
Threads: 208
60
yes. you have to screw the actuator arm in.
Im not sure what the actual limit is for the limited stage 2 but there are pre made limited maps out there that you can down load.
you will also need a front mount intercooler for that sort of power. or you will just have huge heat soak issues
Threads: 3
And where can I download these maps from?
Cheers
21
Hi mate.
Isnt the rover sdi engine the same as the 306 xud?
Threads: 3
So is a sought after colour?
Is it easy to map with a kwp2000+ and with a Windows 8 laptop?
Would it be more beneficial to decat, egr blank and what's a good psi to go upto for now?
Threads: 541
124
Welcome along, love that colour, one of the rarest
