hey all - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: Newbies (https://www.306oc.co.uk/forum/forumdisplay.php?fid=24) +--- Thread: hey all (/showthread.php?tid=16702) |
hey all - LJ_D - 21-08-2013 Hi, I'm LJ from Flintshire, and will be getting a 51 plate 306 hdi estate (meridian) Planning to have a play with like my current rover 220sdi that's running about 140bhp 220+ftlb torque. Hoping to do the usual from what I've read about hdi's. Upped boost via mbc, fmic, cone filter, decat and remap. That should see me to 150+bhp 270+ft lb am I right? Hope to share input with you all. And was told by seller with it being meridian model has lower stiffer suspension, that true as it does seem to sit low to me. LJ Here's couple pics, will take better ones once I get it. ![]() ![]() RE: hey all - Herby7 - 21-08-2013 Welcome RE: hey all - LJ_D - 21-08-2013 Can anyone tell me what colour and paint code it is? RE: hey all - pugjohn306 - 21-08-2013 (21-08-2013, 09:59 PM)LJ_D Wrote: Can anyone tell me what colour and paint code it is? Should be a color code under the bonnet on the passenger side RE: hey all - DazzaHDI - 21-08-2013 Scrap the come filter idea, uprated panel filter is a better bet and definitely an uprated clutch! Welcome btw ![]() RE: hey all - LJ_D - 22-08-2013 Everyone said go for panel filter on my sdi and when I changed to a enclosed cone filter with open front (if you get me) was even better. It's just had new clutch and pressure plate (peugeot original). RE: hey all - Grant - 22-08-2013 Welcome along ![]() RE: hey all - Piggy - 22-08-2013 welcome ![]() RE: hey all - puglove - 23-08-2013 welcome. yes the later meridians had bigger rear TBs & ARBs you will need an uprated clutch friction & pressuer, unlesd you go for a limted torque then you will get away with a new valeo. you will need to winde the boost up manually on the turbo via the waste gate arm. it can be controled with a MBC after that RE: hey all - LJ_D - 23-08-2013 Ok cheers puglove. Damn I was hoping to be able to go all out with torque having a new clutch and pressure plate. What's a safe amount the clutch can go Upto? And the boost upping is that via actuator rod shortening? Cheers. RE: hey all - puglove - 23-08-2013 yes. you have to screw the actuator arm in. Im not sure what the actual limit is for the limited stage 2 but there are pre made limited maps out there that you can down load. you will also need a front mount intercooler for that sort of power. or you will just have huge heat soak issues RE: hey all - LJ_D - 23-08-2013 And where can I download these maps from? Cheers RE: hey all - kingy - 23-08-2013 Hi mate. Isnt the rover sdi engine the same as the 306 xud? RE: hey all - puglove - 23-08-2013 (23-08-2013, 08:33 PM)LJ_D Wrote: And where can I download these maps from? Pro steve & mr whippy sell them, think there are a couple other people out there Didnt notice on my phone earlier but that is cosmic grey, so much want!! thought it was platinum silver earlier RE: hey all - LJ_D - 23-08-2013 So is a sought after colour? Is it easy to map with a kwp2000+ and with a Windows 8 laptop? Would it be more beneficial to decat, egr blank and what's a good psi to go upto for now? RE: hey all - Dum-Dum - 24-08-2013 Welcome along, love that colour, one of the rarest |
