rear hub bearings
rear hub bearings
hi, just renwed the rear brakes today & the threads which the wheels bolt go into on n/s rear hub are fu-bard can i re-tap them out or is it a case for renewal, the bearing is fine, also how hard is the job & are there any precautions i should take before i attack it. cheers
forgot to mention its disc brake on hdi
Yes you can, just depends on how bad they are. Only you know how bad they are, up to you whether to spend the cash on a tap or new hub.
bearing/hub arent that expensive and as long as you have a puller its not tricky
I have just replaced both on my hdi and it is not that difficult took less than an hour a side and that was with a tea break! As Piggy said you will need a puller and on mine it came off quite easily, but left the inner race of the bearing still on the shaft so i just used the puller behind that and it came off easily too.
If it was me i wouldn't want to mess about trying to re tap it as it is a very important thread you don't want your wheel coming off!!
But then that's up to you.
They are not that expensive when i got mine they ranged from about 50 quid up to about 80 quid.
And if you don't have a puller they are pretty cheap too.
Cheers for the replys but i have replaced it a couple of days ago with a new part cost me £37 Smile , not worth messin with old 1. I took some pics while i was doing the job so i can do my first guide for site.
I know your sorted bit just for future I had damaged threads on one of mine but as it wasn't totally knackered I ran a thread chaser through a little bit at a time with lots of light oil and it's now perfek Smile
  Rear trailing arm bearings 306 d turbo 11 6,739 18-07-2012, 04:07 PM
Last Post: 306 d turbo
