passenger window
passenger window
Ok as it says in the subject passenger window is playing up sometimes it works other times it wont has always had the problem just never been botherd about it. now it's hot I want to get it sorted I no they have been known to play up in the past but just wondering if anyone had any ideas. Have had the connector off and is clean no grime, and had a check all around its a v reg.
any ideas as to what it might be would be great
Cheers craig.
A pillar wire broken... unfortunately the problem wire could be in the loom to either door
Is there any quick way of finding out or is it a case of stripping off the pillars and going from there?
Cheers
wind the window up and down while opening/closing each of the front doors.... if you get any changes then that is the side to start looking..
Will be a broken wire in the drivers door flexi loom Smile
IS it easy enough to fix?
err its very fiddly! Time to get the soldering iron out. Open the door and find the rubber tube leading from the body to the door. You will see a cable tie around it. Cut it and pull the rubber back to expose the cables.
  Passenger Window wont go up! mspdan 2 2,519 17-01-2015, 11:33 PM
Last Post: shazilla
  Wiring loom needed/passenger window stuck open... Mattinthehat 4 3,812 18-09-2014, 03:30 PM
Last Post: Mattinthehat
  passenger window doesnt run all the way back up wacker315 3 2,880 18-07-2014, 08:15 AM
Last Post: Richieboi13
