Possible Head gasket?
Just had the 6 hit 90* sat in traffic put the heaters on and its blowing hot for a few seconds then getting cooler but the temp isn't dropping far on the gauge?
Also as in my other topic has been missing a tiny bit on startup after its been sat overnight which clears with a rev
Tell me that im wrong please ? Lol
Sounds like you need to bleed the coolant. Sounds like a airlock to me!
Yeah I had this, thought it was headgasket, turned out it was just an airlock, had me worried for a day or two though!
Waited for it to cool down a bit popped the rad cap off plenty of water and not lost any put it back on and in the same scenario its staying hot
So hopefully all good
Have you re-bled it since Europe ? You have a phase 1 rad and you need to make a header tank which we didnt do in Europe
[Image: 65613_10200761612710317_1548698655_n_zps68c27004.jpg]
CONVOI EXCEPTIONNEL
You'll have a lot of pressure in the header tank if it's HG
Black mask Service
(05-08-2013, 08:05 PM)martyn92 Wrote: Have you re-bled it since Europe ? You have a phase 1 rad and you need to make a header tank which we didnt do in Europe
Say what only just seen this,,
How can you tell the difference thought the rads were the same throughout
And when you say make a header do you mean the coke bottle trick?
the phase1 rad has its header tank built in.
no need to double up.
Yeah down the side of the rad but it's lower than than all the bleed points, 99% sure you need to. Every time I have used a coke bottle and seen massive amounts of air being released
CONVOI EXCEPTIONNEL
90 degrees is normal in heavy traffic. They go to 97 degrees before the slow fans kick in and at 106 degrees the high speed fans kick in.
But it does sound like an airlock to me
When mine went, the coolant turned into choco milkshake.
  head gasket change si124 1 2,091 16-03-2015, 03:09 PM
Last Post: bashbarnard
  XU10 thicker head gasket (see newbies too) Ephrem 6 5,828 11-07-2014, 03:49 AM
Last Post: Dave
  Gti head gasket woes Niall 8 5,542 21-08-2012, 04:50 PM
Last Post: Fooby
