Threads: 141
35
(31-07-2013, 09:03 AM)Piggy Wrote: I actually didnt think droplnks were fail able items...only advisories. meh. get it sorted anyway!
And mate, theres some pretty awesome racing/tuning companies round hereford, with rolling roads, get it booked in and get some accurate figures to stop us all arguing
I'm going to sort a proper exhaust and lows out first then chuck it back on the dyno. Maybe organise a shootout day for my 3 cars haha
Threads: 541
124
You know its bad when you need a dyno day just for you own cars lol
Threads: 163
53
Car Model/Spec: 406 HDI
(31-07-2013, 12:01 AM)Ruan Wrote: Huh?? This car loaded up fine on the dyno, it's a stock turbo 2.1!! The graph is fine, as I said to Zakk, it's simply the exhaust making that crap figure, had the pipe come off that'd have made 150hp...
Daves T04e 306 is a completely different kettle of fish here...
*snip* science *snip*
Edited :p
(31-07-2013, 09:12 AM)ozonehostile Wrote: (31-07-2013, 09:03 AM)Piggy Wrote: I actually didnt think droplnks were fail able items...only advisories. meh. get it sorted anyway!
find a decent rollers and Im sure we'll all come
Threads: 141
35
Well it's not good news :-( the sedan has developed an alarming oil burning habit, going to investigate later but I'm thinking possible turbo failure, overflowing catch tank or worse case scenario, piston rings or something equally sinister
my dibs is that all that coaling had filled the catch tank!
Threads: 138
72
Car Model/Spec: Mincebus
Blocked breather?
Astor 'X' 4 GTi6- 6 - SOLD!
Threads: 141
35
Im hoping it's something to do with the catch tank /breather, nice easy fix
Threads: 541
124
Just a thought, new bonnet now with lining squishing the breather that runs over the top of the inlet?
Threads: 106
7
Car Model/Spec: GTi-6
^^ This.
It doesn't take much to get it burning oil.
I had a kink in the breather pipe on my XUD and it was alarming how quickly it used oil. Re-routed the pipes and never used a drop after that.
JP
JP
Threads: 141
35
(02-08-2013, 01:36 PM)Dum-Dum Wrote: Just a thought, new bonnet now with lining squishing the breather that runs over the top of the inlet?
Nah I took the liner off as soon as I got home lol
Threads: 541
124
Hmmmm, whats the contents of the breather tank at the moment.
Have you checked the bend off the breather at the start as its really tight.
Also have you tried running with the breather open just to test.
Threads: 141
35
I think I've solved it :-)
Where I've had the boost hose off to access the fuel pump for mot yesterday I've put the breather pipe on the wrong side causing it to double back on itself. Gave it a few revs and it seems to be burning without oil :-)
well done, good lad.
div.
Threads: 141
35
(02-08-2013, 03:11 PM)Piggy Wrote: well done, good lad.
div. Haha fu :-P
Threads: 541
124
TBF that breather is a PITA, just nowhere sensible to route it.
Threads: 141
35
(02-08-2013, 03:54 PM)Dum-Dum Wrote: TBF that breather is a PITA, just nowhere sensible to route it.
Yes very true. Thinking of getting a hard 90 degree elbow off the filler neck and some longer hose to route it around the front of the bay instead of over the top
Threads: 141
35
So the exhaust finally got sorted, the "proper" way ;-)
cool...I still have my side exit somewhere...had to 'adjust' brake pipes to make it fit tho
Threads: 141
35
This is just a temporary solution until I find someone to tig weld my stainless. It's good fun though haha. 2.1 sounds great with a straight pipe btw, really growly
bloody loud init.
I had to remove mine when I moved as it wasnt very social...or posh!
growled like a angry lion with a sore throat stung on the nose by a wasp!
Threads: 141
35
(04-08-2013, 12:39 PM)Piggy Wrote: bloody loud init.
haha, thats one way of putting it
Threads: 343
15
Given 3 thank(s) in 3 post(s)
Has it made a difference in power now its a straight pipe?? hows the clutch holding up?
Threads: 141
35
The turbo spools almost instantly and midrange power feels a lot more. But yeah, this has resulted in a bit more 4th gear clutch slip
Threads: 343
15
04-08-2013, 04:57 PM
(This post was last modified: 04-08-2013, 04:58 PM by Chris_90.)
(04-08-2013, 04:16 PM)ozonehostile Wrote: The turbo spools almost instantly and midrange power feels a lot more. But yeah, this has resulted in a bit more 4th gear clutch slip
Needs a bigger turbo then  . Like a truck turbo
Threads: 141
35
I'm trying to keep this sensible enough to use daily. Although once it's slammed and looking nice I guess I won't be able to resist the traditional 11mm pump and big turbo
Threads: 343
15
04-08-2013, 07:11 PM
(This post was last modified: 04-08-2013, 07:11 PM by Chris_90.)
(04-08-2013, 04:59 PM)ozonehostile Wrote: I'm trying to keep this sensible enough to use daily. Although once it's slammed and looking nice I guess I won't be able to resist the traditional 11mm pump and big turbo
Sensible??  side exit loads of smoke, slammed.... All the things that arnt sensible
Threads: 141
35
Well heres the result of an evening of bodgery
Threads: 86
im distracted by the height in the video lol
Threads: 141
35
(04-08-2013, 09:23 PM)padge Wrote: im distracted by the height in the video lol
yeahh it does look pretty tractor spec in pictures :/
not for long though
