24-07-2013, 10:33 PM
So all sorted now? seems like I have a rattly bearing now too so will be doing this job shortly
Puglove's onxy 'state, bye bye
25-07-2013, 05:50 AM
That LUK clutch looks quite worn to me!
Well done though chap...you are no longer a clutch virgin, congratulations! Wishes for more power...
25-07-2013, 11:58 AM
AAHHH think I could well be in need of a gearbox and it wasn't the clutch atall!! f*cking hdi's!!
25-07-2013, 12:00 PM
Just whack your spare DT box on it if you've still got it? just swap the bits from the HDi box?
25-07-2013, 12:03 PM
Aint got a spare apart from on Ryans old car.
138 BHP XSI
25-07-2013, 12:04 PM
I got a DT box here!! you can have it for free if you come get it!
25-07-2013, 12:16 PM
shit one dude! makes me think twice about just whacking a clutch in mine as the box seems a bit notchy atm too
25-07-2013, 03:40 PM
Gearbox needed the had to take it out again and roll the car back
BECAUSElightweightracestate?
25-07-2013, 05:15 PM
Nice chain in there! That's something else. Any you've saved weight. See, the pros are adding up!
Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
25-07-2013, 05:16 PM
custom solid engine mount is that
03-08-2013, 08:58 PM
Well its back together and running, clutch is a lot better......... But its still howling like f*ck, so that rules the clutch & box out, gota be a wheel bearing right? but it spins fine and cant seem to feel any play in it??? is this even possible
well any way as I stupidly thought it was all going to run fin it it was going to be happy days, I treated the state to coilies,clones & pressed plates
03-08-2013, 09:13 PM
still howling?
so when you driving it doesnt change when you pop it in neutral?! Wishes for more power...
prefer the old wheels. Looked awesome! But loving the new lows!
03-08-2013, 10:16 PM
Ooh I like it. Agree with matt though, needs something more exotic than clones
03-08-2013, 11:37 PM
Jack the car up spin the wheel and hold the spring at the same time if it vibrates possible wheel bearing or could be drive shaft as mine was humming before it went
03-08-2013, 11:54 PM
(03-08-2013, 09:16 PM)puglove Wrote:(03-08-2013, 09:13 PM)Piggy Wrote: still howling? What Tyre size? I have 205/40s they don't rub.
04-08-2013, 06:39 AM
this howling...did it start when you changed the rear beam, or was it already there??
defo need to do sumit exciting with the clones...looks a bit boring Wishes for more power...
04-08-2013, 07:35 AM
no it was fine for a while James then all of a sudden it started and gt worse quickly.. sounds like front passenger side. what were you thinking?
It might well be shaft sam.. did yours get worse fast? within a few miles? yes kent 205s coilie right down
04-08-2013, 07:41 AM
I much prefer it on the 'clones tbh!
As for howling, yes bearings can go without any 'feelable' play, both became really loud on my estate but couldn't find any issues with the wheels jacked up....
04-08-2013, 08:03 AM
cheers Tomm i think so too
going to grab a hub & shaft later see if that works
04-08-2013, 08:13 AM
try driving it, engine off, gets rids of a lot of noise, should be able to pinpoint it then.
give it a spin up on stands...should be able to hear it Wishes for more power...
04-08-2013, 08:16 AM
(04-08-2013, 08:13 AM)Piggy Wrote: try driving it, engine off, gets rids of a lot of noise, should be able to pinpoint it then. Good idea try towing it
04-08-2013, 08:33 AM
(04-08-2013, 07:35 AM)puglove Wrote: no it was fine for a while James then all of a sudden it started and gt worse quickly.. sounds like front passenger side. what were you thinking? Yeah hummed while driving but as soon as you put your foot down the huming got alot louder then started banging
04-08-2013, 12:38 PM
you should get a knocking with driveshaft. they are rare to hum/whine
04-08-2013, 02:27 PM
turns out it was the wheel bearing. got it off, still no noticeable play spins freely, tiny bit of grease around it, really odd, swapped for a spare hub and its stopped now so it must have been that,
but now the ABS light is on! ffs this car really doesn't like me!!!!!! feel free to donate the mini lites RD, , would love them for this but bank manager says no |
Puglove's supercharged 6, Repaint | puglove | 707 | 349,785 |
24-03-2016, 06:36 PM Last Post: Eeyore |
Mrs Puglove's xsi | puglove | 163 | 72,860 |
09-03-2015, 01:23 PM Last Post: puglove |
The State | maxlee | 23 | 5,615 |
27-01-2014, 07:14 PM Last Post: procta |
