File Line Function
/global.php 961 eval
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
/showthread.php 1651 eval
is this normal or am i loosing the plot
So i was under the rear of my car checking what needs to be anti rust painted when i noticed my wheels sit diffrent my drivers side rear sits closer to the body/chassis is it normal..??...the car dont feel crabby and drive pretty straight...i took a few pics sorry for the quality but you can see what i mean
Left side
[img][Image: 20130803_102651_zps39f03801.jpg][/img]
[img][Image: 20130803_103025_zpse190547f.jpg][/img]
Right side
[img][Image: 20130803_102755_zps141719cc.jpg][/img]
[img][Image: 20130803_102932_zps46811f85.jpg][/img]
Mabey im looking for faults but it dont look right to me lol
(msg sent from hell)
Is the rear wheel cambered over? if so the beam is f*cked
(03-08-2013, 09:54 AM)puglove Wrote: Is the rear wheel cambered over? if so the beam is f*cked
Do you mean leanning over if so no there both straight as far as i can see
The beams have quite big tolerances when fitting, by the book you should have them aligned, a bit like the front setup.
This is what my rear wheel look like iv tryd to get pic as straight as i can lol
[Image: 20130803_105952_zps03579b52.jpg]
[Image: 20130803_110022_zps13369088.jpg]
[Image: 20130803_110251_zps43002ddc.jpg]
beam just needs pushing over to the right mate.
(03-08-2013, 10:11 AM)Niall Wrote: beam just needs pushing over to the right mate.
Ow do i do that lol..so thers nothing actually wrong
take the boot carpet up and you will see some rubber bungs. Underneath them is 6 nuts. Loosen them off and just push the beam over a bit then as far forwards as possible to ensure its not wonky. Oh and obviously do this with the rear off the floor lol.
(03-08-2013, 10:16 AM)Niall Wrote: take the boot carpet up and you will see some rubber bungs. Underneath them is 6 nuts. Loosen them off and just push the beam over a bit then as far forwards as possible to ensure its not wonky. Oh and obviously do this with the rear off the floor lol.
Crist as simple as that lol yhought id have to strip it dowm lol..wont do any dammage if o dont do it right now will it...
Nah its fine! All you might find is if its been tracked before using one of them 2 wheel laser trackers, your tracking might go out as if the beam is sitting slightly wonky, if you straighten it up, they would of tracked it to when it was wonky.
(03-08-2013, 10:26 AM)Niall Wrote: Nah its fine! All you might find is if its been tracked before using one of them 2 wheel laser trackers, your tracking might go out as if the beam is sitting slightly wonky, if you straighten it up, they would of tracked it to when it was wonky.
Lol its not been tracked since i had it lol...but my alloys wont fit on untill i sort it tho will they lol..
Should be fine. Im running ET15s on mine and i have about 1-2mm clearance and the only time ive ever had a problem was with 3 people and all their gear in the car over bumps on the way to fcs lol.
(03-08-2013, 10:35 AM)Niall Wrote: Should be fine. Im running ET15s on mine and i have about 1-2mm clearance and the only time ive ever had a problem was with 3 people and all their gear in the car over bumps on the way to fcs lol.
Ahhh im only gunna run 16"lasers there pretty fat tho lol ill check it and if it fits ill leave it as it is lol
There ET16. Should have miles of gap! lol
(03-08-2013, 10:38 AM)Niall Wrote: There ET16. Should have miles of gap! lol
Ahhh nice one youv been very helpful mate i think you deserve a rep point for that lol..
Bloody hell, Niall just got rep for being helpful and not a lady garden? lol
(03-08-2013, 11:03 AM)Curt Wrote: Bloody hell, Niall just got rep for being helpful and not a lady garden? lol
Hey f*ck you man. Im always helpful! lol
(although i still havent received my rep whistle )
Just FYI lasers are 15" not 16" Smile
And try to Type better, your English is a struggle to read lol
(03-08-2013, 11:38 AM)Matt Wrote: Just FYI lasers are 15" not 16" Smile
lol i cant have lasers then as they messure 16" on outer rim to rim
Get a pick up Smile also what does the tyre size say?
calm down calm down lol im getting round to it lol...
all done now lol
(03-08-2013, 07:14 PM)Matt Wrote: Get a pick up Smile also what does the tyre size say?
tyre size i know this lol 195/55 r15 85v lol
They ARE lasers, and as I explained to John in the chatbox the other day, they are a 15" rim (hence 15" tyres). The face however will be an inch bigger. Wink
It's perfetly normal for one side to sit slightly different, ALL 306s are infact like this, it's due to the rear beam layout, it causes it to sit slightly over...
I don't think I've seen a 306 that isn't like this.
(04-08-2013, 09:22 AM)Ruan Wrote: It's perfetly normal for one side to sit slightly different, ALL 306s are infact like this, it's due to the rear beam layout, it causes it to sit slightly over...
Lol im gunna be on the hunt for another 306 now to check this out lol
(04-08-2013, 07:32 AM)Toms306 Wrote: They ARE lasers, and as I explained to John in the chatbox the other day, they are a 15" rim (hence 15" tyres). The face however will be an inch bigger. Wink
No tom im avin 16"s lol cus i want it to be lol...
But you live on the island Matt. You can't read. You all communicate in dances and clicking noises followed by grunts and screams. You still sacrafice bulls to the gods, burning them at the altar to produce a pleasing odour for the heavens. Every sunday the island elders get together to discuss affairs and arrange arranged marriages (they wouldnt be arranged otherwise). Witch hunts occur every Tuesday at noon, and the screams of 'Burn Her!" can be heard for Gunwharf when the wind blows the right way. The shortage of rain is blamed on the woman down the road with all the cats, and everyone is afraid of Nymphs and Sprites in the woods.
Thats what happens on the island right? I watched it on a David Attenborough show once IIRC.
  Premium diesel over normal JJtheHITMAN 43 19,171 10-01-2014, 08:34 PM
Last Post: JJtheHITMAN
  Does anybody recognise this? Not your normal 306! Tallguy_2 22 13,271 23-03-2013, 06:55 PM
Last Post: Pompey306mark
