what turbo
what turbo
Hi i need a new turbo t reg 1998. what turbo will work on it with modding anythink i here there are a few types
Depends if you want something thats a straight bolt on fit, or dont mind making plates and oil lines and exhausts to adapt it.
Option A, Buy a GT15, K03, K14, T2, They all bolt straight on, sorted.
Option B, Pick a turbo, make plates to adapt, bolt on, hoon.
The pipe on the inlet underneath is the egr i understand this can be blanked
Yeah welded up or i think you can get blanks.
Turbo from a petrol car work if so I've got a turbo from a rover coupe
Depends, if you can make plates to adapt it? It might be miles to big also.
I will try don't no tilll you try
Best of luck my friend Smile
were are you i have my old manifold and tubo turbo is naff but if your moddin it might be some use
Probably a T25 mate
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
From walsall mate
Will a standard 1.9 diesel inlet fit aswell
From walsall
A naturally aspirated diesel inlet? Dont think so.
Yes for the pipe in the middle for fmic
