what turbo - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: what turbo (/showthread.php?tid=16008) |
what turbo - pug_345 - 30-07-2013 Hi i need a new turbo t reg 1998. what turbo will work on it with modding anythink i here there are a few types RE: what turbo - Tom - 30-07-2013 Depends if you want something thats a straight bolt on fit, or dont mind making plates and oil lines and exhausts to adapt it. Option A, Buy a GT15, K03, K14, T2, They all bolt straight on, sorted. Option B, Pick a turbo, make plates to adapt, bolt on, hoon. RE: what turbo - pug_345 - 30-07-2013 The pipe on the inlet underneath is the egr i understand this can be blanked RE: what turbo - Tom - 30-07-2013 Yeah welded up or i think you can get blanks. RE: what turbo - pug_345 - 31-07-2013 Turbo from a petrol car work if so I've got a turbo from a rover coupe RE: what turbo - Tom - 31-07-2013 Depends, if you can make plates to adapt it? It might be miles to big also. RE: what turbo - pug_345 - 31-07-2013 I will try don't no tilll you try RE: what turbo - Tom - 31-07-2013 Best of luck my friend RE: what turbo - ashkid - 31-07-2013 were are you i have my old manifold and tubo turbo is naff but if your moddin it might be some use RE: what turbo - Anton - 31-07-2013 Probably a T25 mate RE: what turbo - pug_345 - 31-07-2013 From walsall mate Will a standard 1.9 diesel inlet fit aswell From walsall Will a standard 1.9 diesel inlet fit aswell RE: what turbo - Tom - 01-08-2013 A naturally aspirated diesel inlet? Dont think so. RE: what turbo - pug_345 - 01-08-2013 Yes for the pipe in the middle for fmic |
