Driveshaft problem.
Driveshaft problem.
So my passengeer sid driveshaft popped the other day, because of a loose balljoint and bushing... so a new wishbone was put in, then when tha went in it popped the second driveshaft. now i think theres a bit of damage where the balljoint goes in the hub, should that make much of a difference? And also , whats the point of the sping in the driveshaft? Smile
[Image: DSC_0054.jpg]
whats a sping??
the hub may have ovalled but I have never known a ball joint cause a driveshaft failure.
(26-07-2013, 02:18 PM)Piggy Wrote: whats a sping??
*Spring ... yeah the hub has ovalled.....
There is no spring in the shaft, where abouts is it put on?
