Threads: 94
7
Car Model/Spec: 205 coming soon
So my mates just rang me asking as he was bleeding his brakes ect and spilt some on his wing. Was on there about 15 mind before he noticed. Will that do any damage or be fine?
Official Team Go-NAD fan club
Threads: 581
195
Get plenty and plenty of water on there. He might be lucky and it may just soften the paint a bit but if it's been on there for that long, it probably will do damage.
Threads: 94
7
How long is it normally before goes tits up?
Threads: 541
124
Yeah as much water as possible and leave its week before you touch it
Threads: 94
7
Does it not f*ck up if you don't touch it then?
Threads: 78
49
Yeah, that's probably enough to do damage. As said, any time you spill brake fluid, water.
Threads: 581
195
Can't really say tbh. I took the fresh paint off my brakes within seconds but that paint was a day old.
Threads: 94
7
Okay he has the hose pipe on it now low pressure and on like mist/sprinkle setting so will soon see
Threads: 581
195
You want to hope it hasn't done too much damage. If it gets down to the metal, that panel will probably need replacing as you can never neutralise it properly (hence why when people do someone's car with it, they don't use nitromors. That's neutralised by water....brake fluid isn't  )
Threads: 94
7
I never thought brake fluid was that bad on paint? Looks like I might be looking for a wing for him soon lol
Threads: 581
195
You may be lucky. It all depends on how long it was on, if it was new or not (I've heard new fluid won't damage paint...how true that is I'm not sure) and the quality of the paint
Threads: 36
18
Car Model/Spec: DT
Given 2 thank(s) in 2 post(s)
Nasty stuff on paint... Likelyhood is that is will need replacing in the long run as even if the damage isn't visable now it will be at some point.
On the 306 waiting list.
Threads: 87
48
i've spilt it on the car before, washed it straight off and it was fine . . . . .
Threads: 236
36
Car Model/Spec: '01 HDi DTurbo
I think people are over-estimating the power of brake fluid.
![[Image: Sig500x130.png]](http://i430.photobucket.com/albums/qq25/chris_rx71/Sig500x130.png)
Threads: 55
17
Car Model/Spec: 406 V6
24-07-2013, 03:34 PM
(This post was last modified: 24-07-2013, 03:35 PM by Rippthrough.)
Depends what it's on, how long it's on, and how old it is.
Old fluid on unlacquered paint (engine bay etc) will get under the paint and strip it in a day, new paint it can take off in minutes. Lacquered paint is generally fine if you wash it off straight away.
Threads: 117
119
24-07-2013, 06:18 PM
(This post was last modified: 24-07-2013, 06:19 PM by Poodle.)
I'm fairly sure dum-dum has a door in his garden that has had brake fluid poured over it, i don't think people are underestimating.
Threads: 541
124
Not any more I dont, all went for scrap yesterday.
But yeah it does take it off well, the problem is most peoples cars you see done it has been on overnight. 15 mins might be OK, it might not. Leaving it well alone for a week or more after a load of water might let it re harden if it has done damage.
Threads: 206
3
Car Model/Spec: 3dr dt-s
it brings cellulose paint off in minutes, but manufacturers started phasing it out in the 80's in favour of 2 pack paint.
modern 2-pack paint, once hardened should be impervious to it..if you are lucky.
its why we tell people to use clean wing covers when working under a bonnet ??
Threads: 31
4
Car Model/Spec: tu5 bitza/cherry dt
Given 5 thank(s) in 5 post(s)
brake fluid will still strip 2 pac paint, a lad at my old workshop had a hick-up with a pressure bleeder and didnt wash the car down for about 10 mins by which point it was waayy too late, stripped the paint in patches on the roof wings and bonnet
Threads: 169
91
Given 1 thank(s) in 1 post(s)
Was it a PSA car? If so he could be lucky. If it was running LHM fluid as standard, this is far more gentle on paint than standard fluid.
The reason old brake fluid is worse on paint than newer stuff, is that the corrosion prohibitive additives degrade over time and become reactive. Hence the corrosion on older braking systems.
You will notice less corrosion on a LHM system, the same age as a glycol-based system (i.e. DOT 3 upwards).
Threads: 42
8
Car Model/Spec: bone rattler 306...
Just to jump on someones thread what could happen if you get break fluid on rubber or electrical wires.????...im planning on changing my resovoir as i seem to have a small leak lol..i will drain it but some dripping is gunna happen....
Ps sorry to highjack a thread...
(msg sent from hell)
Threads: 169
91
Nothing if you clean it off. Remember, there are rubber seals in your braking system anyway. Just be sure to clean it off after
Threads: 236
36
If what you say about the older brake fluid being better for paint stripper I may not throw the old bottle I have away!
I used it for stripping paint from small parts on models. It goes through chrome plating on plastic like teeth through butter...
Threads: 169
91
^^Quality film!
Threads: 386
87
Just thought I'd bump this as it seems brake fluid is bad for paint lol....
Threads: 591
54
yes brake fluid is bad for paint
Threads: 252
7
Car Model/Spec: Xud sedan/Xud estate
I poured some over one of my scrap cars roofs once. Did f*ck all not even a stain.
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 169
91
(17-08-2013, 05:49 PM)HDIkyle Wrote: I poured some over one of my scrap cars roofs once. Did f*ck all not even a stain.
Was it new fluid? Its mainly the old, used fluid that is corrosive. For the reason stated below
(25-07-2013, 12:28 AM)Grant Wrote: Was it a PSA car? If so he could be lucky. If it was running LHM fluid as standard, this is far more gentle on paint than standard fluid.
Threads: 55
17
Yeah, Tom, you're going to have to shift the piping as it'll have got under the paint on the crossmember underneath too, it might look okay but it'll probably rub off with a stiff brush or ever just rubbing with your finger if you check it.
Threads: 386
87
(18-08-2013, 12:03 AM)Rippthrough Wrote: Yeah, Tom, you're going to have to shift the piping as it'll have got under the paint on the crossmember underneath too, it might look okay but it'll probably rub off with a stiff brush or ever just rubbing with your finger if you check it.
It's the moonstone that I'm breaking so doesn't matter lol.
