Threads: 127
33
Car Model/Spec: ZX Volcane TD
Given 31 thank(s) in 31 post(s)
should be fine, as long as you only want to read up to 1000 degrees
Threads: 591
54
16-07-2013, 12:40 PM
(This post was last modified: 16-07-2013, 12:41 PM by Piggy.)
surely above 1000 is bad though...so hitting max would tell me to stop being so heavy with the go pedal?
secondly:
with gearbox mounted turbo, it brings me the doubt as where is best for the probe?
Threads: 198
135
At the collector in the mani tbh. How are you relocating your turbo? A flanged pipe on standard mani or equal length runners round to the turbo?
Ideally you want two, one pre-turbo and one at the exhaust mani to keep an eye on the head temps
Threads: 591
54
yeah was thinking that.
standard mani, flange, pipe to turbo.
was thinking of using the egr hole in the manifold then put one just after turbo on the downpipe
Threads: 198
135
Stick one at the collector on the exhaust mani and one as close to the turbo as you can, PRE turbo. No point in having one after the turbo.
Threads: 591
54
whats the point in having one just pre turbo if theres one in the mani?!
Threads: 198
135
Because you want to know the temps heading into the turbo to know if you're cooking it. On a normal setup you want it in the mani just before the turbo. With your setup, you can measure temps just as they exit the head, and just as they enter the turbo. That way you know how hot your head is getting AND how hot your turbo is getting too.
Even 60-70cm of pipe can throw off your EGT's going into the blower, could be anything up to a couple of hundred degrees out.
Threads: 91
83
I'd have it wherever the collector is, that way you have a good average... Right at the head is a fail, unless you have amazing manis you'll end up with one cylinder hotter due to dodgy afrs across all 4...
Right before the turbo is also a recipe for fail as you could be cooking the head but turbo is fine...
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in.
