EGT gauge - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23) +--- Thread: EGT gauge (/showthread.php?tid=15584) |
EGT gauge - Piggy - 16-07-2013 I would really like to fit a digital EGT gauge, OEM style in the dash, bit like the one cully done for his boost. I can find a digital screen cheap... http://www.ebay.co.uk/itm/Digital-DC-Temperature-Meter-for-K-Type-EGT-Probe-C-/250845009355?pt=UK_BOI_Electrical_Test_Measurement_Equipment_ET&hash=item3a678715cb but is 1000degrees enough and the K type thermocouple input, this would work ok with it??: http://www.ebay.co.uk/itm/EGT-EXHAUST-GAS-TEMPERATURE-SENSOR-PROBE-UNIVERSAL-FIT-K-Type-Thermocouple-for-/180991856755?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2a23f49073 RE: EGT gauge - zx_volcane - 16-07-2013 should be fine, as long as you only want to read up to 1000 degrees RE: EGT gauge - Piggy - 16-07-2013 surely above 1000 is bad though...so hitting max would tell me to stop being so heavy with the go pedal? secondly: with gearbox mounted turbo, it brings me the doubt as where is best for the probe? RE: EGT gauge - cwspellowe - 16-07-2013 At the collector in the mani tbh. How are you relocating your turbo? A flanged pipe on standard mani or equal length runners round to the turbo? Ideally you want two, one pre-turbo and one at the exhaust mani to keep an eye on the head temps RE: EGT gauge - Piggy - 16-07-2013 yeah was thinking that. standard mani, flange, pipe to turbo. was thinking of using the egr hole in the manifold then put one just after turbo on the downpipe RE: EGT gauge - cwspellowe - 16-07-2013 Stick one at the collector on the exhaust mani and one as close to the turbo as you can, PRE turbo. No point in having one after the turbo. RE: EGT gauge - Piggy - 16-07-2013 whats the point in having one just pre turbo if theres one in the mani?! RE: EGT gauge - cwspellowe - 16-07-2013 Because you want to know the temps heading into the turbo to know if you're cooking it. On a normal setup you want it in the mani just before the turbo. With your setup, you can measure temps just as they exit the head, and just as they enter the turbo. That way you know how hot your head is getting AND how hot your turbo is getting too. Even 60-70cm of pipe can throw off your EGT's going into the blower, could be anything up to a couple of hundred degrees out. RE: EGT gauge - Piggy - 16-07-2013 coolio....I be on that soon! Repd ![]() RE: EGT gauge - Ruan - 16-07-2013 I'd have it wherever the collector is, that way you have a good average... Right at the head is a fail, unless you have amazing manis you'll end up with one cylinder hotter due to dodgy afrs across all 4... Right before the turbo is also a recipe for fail as you could be cooking the head but turbo is fine... |
