Hdi ecu set
Wanted: Hdi ecu set
After a hdi ecu set for a mate of mine
Anyone? Smile
Used to have one on my old one. I have map file for it though
I have a single plug hdi ecu with matching bsi which has a pro steve S1 map you can have cheap. Can also bring to FCS if needed
HDi Cabby Project Click
Does it come with the chip out the key also? Just need to replace a mates ecu that is dead Smile
No mate, unfortunately not although I'm sure the keys can be coded with PP
There is a small chip in the key case that's the imbaliser chip.
Yea but I'm sure you can code a new key to the bsi with Peugeot planet
