Wanted: Hdi ecu set - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: For Sale (https://www.306oc.co.uk/forum/forumdisplay.php?fid=26) +--- Forum: Misc & Wanted (https://www.306oc.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Wanted: Hdi ecu set (/showthread.php?tid=15333) |
Hdi ecu set - spike2002 - 08-07-2013 After a hdi ecu set for a mate of mine ..... RE: Hdi ecu set - spike2002 - 13-07-2013 Anyone?
Re: Hdi ecu set - kentiiboii - 13-07-2013 Used to have one on my old one. I have map file for it though RE: Hdi ecu set - londondan86 - 14-07-2013 I have a single plug hdi ecu with matching bsi which has a pro steve S1 map you can have cheap. Can also bring to FCS if needed RE: Hdi ecu set - spike2002 - 14-07-2013 Does it come with the chip out the key also? Just need to replace a mates ecu that is dead
RE: Hdi ecu set - londondan86 - 14-07-2013 No mate, unfortunately not although I'm sure the keys can be coded with PP RE: Hdi ecu set - spike2002 - 17-07-2013 There is a small chip in the key case that's the imbaliser chip. RE: Hdi ecu set - londondan86 - 17-07-2013 Yea but I'm sure you can code a new key to the bsi with Peugeot planet |
