Ignition live
Ignition live
Wiring up a boost gauge, what wires have you used?
Taken mine off the fag lighter and switched the fuse over so its ignition live.
Oh really? Would using a live from the CD player work?
Electrics really are not my strong oiint
Could do it of the headlights adjust panel?
on the 205 - the cigarette is a constant live.
get a multimeter and test some on the hazard switch
I have no multimeter on me at the moment, the headlight adjust switch has a constant live or ignition live?
Actually doesn't that panel only power up with the headlights?
it's going to be hard to find it.
If i said to you find the green wire on the hazard switch, again, a tough thing to find. You'll be shooting in the dark.
What you up to tomorrow?
Unfortunately working all day Sad there is a green wire on the hazard switch?
Exactly.
It's hard without testing them Sad
I done mine yesterday on the 205, a couldn't tell you which colour it was Sad
Bollicks. @cully or Niall, got a wiring diagram?
Took mine from the orange wire on the rheostat, that way it dims if you dim your dash lights. I also added a resistor in line to dim it a bit, matches in much better like that IMO.
if you have a wire long enough, go from the dash lights dimmer switch, thats what I always do so you can dim the gauge with the rest of ya dash
(10-07-2013, 04:19 PM)Matt Wrote: Bollicks. @cully or Niall, got a wiring diagram?
yes!
use the search function like everyone else
ffs Mods take such liabertys
Big Grin
(10-07-2013, 04:44 PM)Jonny81191 Wrote: Took mine from the orange wire on the rheostat, that way it dims if you dim your dash lights. I also added a resistor in line to dim it a bit, matches in much better like that IMO.
(10-07-2013, 04:47 PM)Piggy Wrote: if you have a wire long enough, go from the dash lights dimmer switch, thats what I always do so you can dim the gauge with the rest of ya dash
Isn't that what I just suggested?
yes!
Big Grin
yes!
Big Grin
There is a thread? I even searched....
tiz. we agree. I started my post, then came back to it...overlap.
dumbasses thinking alike
Fair enough lol
[Image: DSCF5799.jpg]
red = 12v ign
green/yellow = 0v ground
(10-07-2013, 07:04 PM)cully Wrote: [Image: DSCF5799.jpg]
red = 12v ign
^ is that the dash dimmer or headlight adjuster
NO SMOKE NO POKEBig Grin
red = 12v ign
its the headlight adjuster!
the dash dimmer only has orange wires
I took my ground from that plug but live from the dimmer
Bloke previous to me had spliced straight into the ignition live and then wrapped bare wire around the clutch pedal for the ground. Don't do this. I was very f*cked off to discover it and it took ages to unravel!
[Image: Sig500x130.png]
(04-09-2013, 10:31 AM)xiaomianmian Wrote: if you have a wire long enough, go Fifa 13 Community from the dash lights dimmer switch, thats what I always do so you can dim the gauge with the rest of ya dash
I always wire my things through football lmao
  Radio ignition live Dean 3 1,084 27-11-2013, 05:54 PM
Last Post: DTurboTom
