Threads: 9
Car Model/Spec: Diablo 6
Hi all I recently purchased a gti6 and I'm having some running issues hope someone can help me. The car idles fine and revs up nicely but every now and then when it is idling if you rev it it will return to Idle speed And then drop below idle speed struggle to pick up again and then cut out completely. Any help you can offer Would be greatly appreciated.
Threads: 63
26
Car Model/Spec: GTi6
Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
As vaughan said its probably the ICV, best bet would be to take it off and give it a clean with some carb cleaner
Threads: 9
Thats guys I'll have a look at it tomorrow. If it's dead do you know a good place to get a new one? Ebay?
Threads: 63
26
Threads: 208
60
Given 5 thank(s) in 5 post(s)
99% its ICV . Dont be tempted to buy a cheap repoduction they dont last 5mins. And you will be forking out for a genuine one a couple months down the line anyway
Best bet is to go to peugeot and get one 1st time around. Be warned though they arnt cheap
Threads: 169
91
Given 1 thank(s) in 1 post(s)
As said, don't go cheap. Look for 'Magnetti Marelli' they pop up reasonably enough priced on ebay from time to time and are OE quality stuff.
Threads: 9
Cheers guys. Iv had the icv off the car today and cleaned it with Carb cleaner but it's made no difference. I'm guessing it's probably broken then. Or could it be the coil packs?
Threads: 169
91
Wouldn't be coil packs as that would cause a misfire not an idle issue. Did you grease the ICV after cleaning it?
Threads: 9
Yeah right true I don't get any miss firing. No I didn't grease it just gave it a good clean. Couldn't really see any moving parts to grease. Which bit do I grease the silver tip?
Threads: 169
91
No, you want to grease the shaft (whey!). What it does is slide in and out (whey!) to control the air moving through the TB when the butterfly is closed, thus adjusting the idle.
Threads: 9
I'll strip it off again tomorrow whey lol and then wd40 it to death.
Threads: 169
91
Perhaps use some white spray grease, or LM grease, as WD 40 will eventually dry off and can be damaging to rubber
Threads: 581
195
(27-06-2013, 05:08 PM)Grant Wrote: Perhaps use some white spray grease, or LM grease, as WD 40 will eventually dry off and can be damaging to rubber ![Smile Smile](https://www.306oc.co.uk/forum/images/smilies/smile.png)
This. I used white grease and worked very well. Dont worry about using WD to clean it though as there is no rubber in them
Threads: 80
10
Magneti Mareli ICV for substantially cheaper than Peugeot
http://www.carparts4less.co.uk/search/436730100/p/home
Boom
![[Image: sigjpg.jpg]](http://i44.photobucket.com/albums/f32/cassandra--gemini/sigjpg.jpg)
Serious.
Threads: 169
91
That's the kiddy. Just be warned there are two different types; one has the bolt holes offset to the pin, and the other doesn't
Threads: 9
Thanks guys cheers for the link. Gona grease it up tomorrow see if that helps any if not I may pick up a new one off that site
Threads: 9
Well I took it off and greased it but I guess iv broke it as now all the car does is rev at 2000rpm constantly. Guess I need a new one
Threads: 80
10
First, try resetting the ecu by removing the negative terminal on the battery for 30 mins.
Serious.
Threads: 9
Alright I'll give that a try on Monday when I next free. Just worried now that iv gone and cause another issue. Couldn't understand how cleaning it has made the idling go crazy. Its almost like the valve is stuck open or something lol
Threads: 9
(28-06-2013, 05:01 PM)lewisdmz Wrote: First, try resetting the ecu by removing the negative terminal on the battery for 30 mins.
Sorry to be a pain, I do appreciate the advice. If I was to replace the icv I'm guessing I still would need to reset the ecu? Or should it just work instantly..
Threads: 10
3
Car Model/Spec: GTI-6
I would reset the ecu mate. Just to clear it and start a fresh. I had this problem few weeks ago
Threads: 9
(29-06-2013, 09:02 AM)Puggie Wrote: I would reset the ecu mate. Just to clear it and start a fresh. I had this problem few weeks ago
Good to know thanks. Is it just as simple as disconnecting the negative side of the battery? I'm not very mechanical as you can tell lol
Threads: 169
91
Yeah as said leave it off for 30 mins to an hour an the memory in the ecu blanks as there is no power for the storage
Threads: 9
(29-06-2013, 09:32 AM)Grant Wrote: Yeah as said leave it off for 30 mins to an hour an the memory in the ecu blanks as there is no power for the storage ![Smile Smile](https://www.306oc.co.uk/forum/images/smilies/smile.png)
Cool well I'll give it ago and report back, just gona hope it works lol
Threads: 465
114
Car Model/Spec: Vauxhall
dont just remove the ICV motor, remove the plastic body it mounts too as well, clean this too as this is the bit that carbons up
Threads: 9
(29-06-2013, 10:28 AM)cully Wrote: dont just remove the ICV motor, remove the plastic body it mounts too as well, clean this too as this is the bit that carbons up
Yeah I gave that a good clean too. Just random how the revs have got messed up. But I'll try the reset on Monday and go from there. Hopefully nothing else has got messed up lol
Threads: 9
Sorry to report chaps but the ecu reset did nothing. Still idles at 2000rpm. If you give it any revs it goes up and sometimes sticks and others drops back to 2000. Sometimes it starts at normal revs but slowly goes up on its own. Fells like the valve is stuck or something.
Threads: 448
51
I'd be stripling the the icv, giving a really thorough clean and grease up, clean out the pipe that comes off the icv, also cleaning the butterfly valve making sure that is getting stuck slightly. Also check throttle cable is connected right.
Also check you actually plugged the icv back in and done the bolts up nice and tight. Also check the o ring seal it has and make sure it's all together correct
Threads: 9
(01-07-2013, 01:44 PM)Matt Wrote: I'd be stripling the the icv, giving a really thorough clean and grease up, clean out the pipe that comes off the icv, also cleaning the butterfly valve making sure that is getting stuck slightly. Also check throttle cable is connected right.
Also check you actually plugged the icv back in and done the bolts up nice and tight. Also check the o ring seal it has and make sure it's all together correct Thanks I'll strip it off again tomorrow then. I haven't touched the throttle it is brand new cable. When I took it off the first time it was fine but didn't resolve my stalling issue. It has only been since I took it off again and pulled the black sleeve back to crease the shaft that this new problem has appeared. Thinking maybe I have damaged it or something
