Dturbo from an xsara into a 306?
Engine went in a friends 306 98 dturbo. would a xsara dturbo engine fit straight into a 306? simple enough swap?
[Image: DSC_0054.jpg]
yes, some had a semi ecu controlled fuel pump which is easy enough to swap for a 306 bosch and the rev counter sensor is different but just a case of putting a 306 fly wheel on solves that
(28-06-2013, 07:49 PM)ozonehostile Wrote: yes, some had a semi ecu controlled fuel pump which is easy enough to swap for a 306 bosch and the rev counter sensor is different but just a case of putting a 306 fly wheel on solves that
Sounds good Smile is there a guide on this for an engine swap?
