Dturbo from an xsara into a 306? - Printable Version
+--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11)
+--- Thread: Dturbo from an xsara into a 306? (/showthread.php?tid=15051)
Dturbo from an xsara into a 306? - Darren123 - 28-06-2013
Engine went in a friends 306 98 dturbo. would a xsara dturbo engine fit straight into a 306? simple enough swap?
RE: Dturbo from an xsara into a 306? - ozonehostile - 28-06-2013
yes, some had a semi ecu controlled fuel pump which is easy enough to swap for a 306 bosch and the rev counter sensor is different but just a case of putting a 306 fly wheel on solves that
RE: Dturbo from an xsara into a 306? - Darren123 - 28-06-2013
(28-06-2013, 07:49 PM)ozonehostile Wrote: yes, some had a semi ecu controlled fuel pump which is easy enough to swap for a 306 bosch and the rev counter sensor is different but just a case of putting a 306 fly wheel on solves that
Sounds good Smile is there a guide on this for an engine swap?
