Check straps
Check straps
My check straps make a clunking noise due to the pin being loose. I don't really want to buy the whole check strap unit because they are £30 quid each, but I could just get the brackets and pins, which would stop the pin moving in the bracket. Am I right in thinking this would stop the clunking, or does the actual strap also need to be a good fit on the pin?
Thanks
[Image: 20120704_212316.jpg]
Normally a bolt will do it. Clean the f*ck out of the joins etc, grease them
Up and that should help
A bolt instead of a pin? Surely that would be a looser fit?
Make sure it's snugg Wink
Pin should sort get a bigger one, check the 2 nuts are tight that hold the strap to the door, they'll make a racket when there loose aswell.
The pins are circa £0.80 from pug IIRC. THere are two different size dependant on phase, but for that price who cares lol.
If you do end up being a tight arse and using a bolt, make sure you fit washers and a nyloc nut and don't tighten it fully. It will work lose otherwise Smile
I think its worn behond the point that a new pin would work, its been like it for 2.5 years! Will definatley need a new bracket with the pin, just hopefully not check strap
You could drill out the bracket and strap a bit bigger and put in a biggervsize pin to match.
Yeah I might end up doing that I'll have another look and see how bad they are
You do know a check strap and pin are only 11 quid ?
(26-06-2013, 06:16 PM)Puggie Wrote: You do know a check strap and pin are only 11 quid ?
Where? There £30 from dealers.
You could get one from the breakers yard but get the N/S one as that should have less wear on it.
£15 from pug last time i checked
3 Door 00009181E5 ARRET DE PORTE AVANT 24.89 GBP 29.87 GBP 29.87 GBP
5 Door 0000918173 ARRET DE PORTE AVANT 20.73 GBP 24.88 GBP 24.88 GBP
Dealer discout bitches Big Grin
(28-06-2013, 03:43 PM)Puggie Wrote: Dealer discout bitches Big Grin
So they are not 11 quid..
£25 from pug and that doesnt include the bracket or pin, have to buy them seperately I'd guess they'd be around a tenner
(28-06-2013, 06:26 PM)Ben Wrote: [quote='Puggie' pid='288477' dateline='1372434196']
Well they are aye saying ive just payed 11 quid for the strap and pin Rolleyes
(28-06-2013, 06:26 PM)Ben Wrote: £25 from pug and that doesnt include the bracket or pin, have to buy them seperately I'd guess they'd be around a tenner
9181E5 is the whole thing. That's the number I used when I got one and it was a complete unit.
  What are the straps in a rallye? Eeyore 18 3,804 10-05-2016, 09:39 PM
Last Post: insomaniac45
