11-06-2013, 03:58 PM
After the Xantia's disgraceful failure at the MOT, I need some new wheels. The Xantia needed to much welding to keep on the road and it was now leaving big trails of hydraulic fluid on the road everytime I braked so I couldn't drive it. I didn't want to spend too much. I just wanted something cheap to run around in while I got my 306 back on the road.
Anyway, a bit of late night Ebay bidding got me this:
It's a Saab 93 2.0l with low pressure turbo giving 154bhp. This one dates from 2000 with 104k miles on it. The main faults in the ad were non working ventilation controls (common Saab fault), very stiff handbrake and body scuffs and scrapes. Yet again, it was an elderly chap selling the car. He was the second owner and had bought it from the local Saab dealer 6 years ago. He'd mainly used it for going back and forth from the golf course so I think it's probably had quite an easy life. Unfortunately, he'd lost the service history but the biggest problem was that it only had 2 weeks MOT so it was a bit of a gamble.
So, the first job was to take it for an MOT and see how much work was needed. I couldn't believe it when it passed first time! I did get a bunch of advisories for the handbrake, brakes hoses slightly perished, minor exhaust leak, uneven wear on front tyres and a bit of imbalance on the front brakes.
So, important jobs are:
Brakes - fix handbrake and check front brakes over
Service - It was last serviced May 2012 and there’s a slight misfire occasionally so spark plugs probably need replaced
Ventilation controls: Need to open it up and see if I can araldite the shafts or need to buy new ones (about £15)
Less important:
Stereo - only 1 speaker works and electric aerial is clunky
Lighter socket – my phone charger doesn’t work unless you push it in all the time
Exhaust - has a minor leak somewhere but passed MOT
Tracking- wearing inside of tyres out and the steering wheel is not quite straight
Rust – filler flap and rear arch
Paintwork – needs a good polish
Bonnet badge – missing!
Future improvements:
Fix turbo – No lpt for me! Fit T7 apc and get ECU remapped
Tyres – Current tyres are good for a while yet but will start looking now on Gumtree and Ebay for a cheap set of nice alloys with good tyres
Piggyback rear arb – very cheap and effective suspension improvement: http://www.uksaabs.co.uk/UKS/viewtopic.php?f=3&t=11397
Fit cruise control – apparently all the wiring, etc is there and you just need to change the indicator stalk then get someone to reprogram the trip computer: http://www.uksaabs.co.uk/UKS/viewtopic.php?f=2&t=92382
Add remote central locking: I think I replace TWICE unit and get someone to reprogram the thing
Fit leather seats – oooh posh!
Fit missile launchers – help with traffic congestion
Anyway, enough text! More pictures:
As you can see from the last pic, it could do with a wash. As a reward for passing it's MOT I gave it a nice bath:
That purple stuff is brake dust being removed by Wolf Chemical Brake Duster.
My 306 has no ECU at all so I don't know too much about all this computer stuff. The last time I read codes was on my Ford Sierra with a thing that blinked an LED that you need a degree in morse code to understand! Things are much cooler now. I bought this off Ebay:
I've just downloaded the Torque app for my Android phone so I'm away to see what it says now!
Less important:
