Help, broke down!
Help, broke down!
(21-05-2013, 07:13 PM)tbaxter08700 Wrote: Yeh but it can't be the be the lift pump if I am getting correct cranking fuel pressure?!
This is a HDi......it doesn't have to make sense! lol
If it were me, I'd try a good LP pump just for piece of mind really, its cheap to do and 'most' HDi non-starts seem to be caused by the lift pump if you look through google. And if yours was already dodgy before....
You could have more than one issue tbh.....
(21-05-2013, 07:18 PM)Ruan Wrote: Have you actually checked that the cam/crank is in time, hence why the synchronization would be out?
Something definitely sounds fishy, though...
The sync was out as he didnt test while cranking, going to get him to check that when he comes thur.
Yeh I think there maybe be more than one issue too.
Might just get a new car...... thinking a 307!?
(21-05-2013, 07:29 PM)tbaxter08700 Wrote: Might just get a new car...... thinking a 307!?
Hmm, ever heard the saying 'jumping from the frying pan into the fire'? Confused
If you only had the fault a couple of times and it disappeared again it's probably an intermittent electrical fault, rather than the lift pump itself. I shouldn't bother buying a second-hand one, you just don't know what you're getting and how long it'll last. Check the lift pump if you like, but i'm almost 100% certain it's not your problem.
Have you tried most of the other tests listed in my thread?
No it always stayed but if I cleared it then it wouldn't come back unless I actually drove so that's is not showing now? !
Ah i see, thats me misreading things again, sorry.
If you've had that happen regularly you've got fuelling problems, its almost certainly related to your non-starting issue. Theres a few things you can do yourself to test stuff as listed in that thread I linked. Another vote here for starting with the lift pump.
Breaking or selling as it is lads Sad
Noooo, you've come so far, you can't give up on it now lol!
I know mateSad
