Break wear sensors
Hi guys looking to change front break pads on my 306 but dont know weather I neee pads with or without wear sensors. How do I find out?
[Image: 2jcaw6b.jpg]
Have a look on top of the hub. There is a rubber connector with two holes for two bullet connectors. If you have this, you have pad wear sensors. Tbh id just not worry and just get non sensor pads. Wont make a blind bit of difference!
Will it not display as a warning light on the dash without them though?
Nope. Ive cut mine off and no lights at all Smile
It brings the warning light on when the pads had worn down, wear through the wire, which completes the circuit through the disc. So if you rip the wires off, they can't complete the circuit and can't bring the light on
  Uneven rear tyre wear rydon 12 8,831 13-06-2019, 04:18 PM
Last Post: Nexus
  Fitting A New Break Servo TommiePuglet 19 13,877 05-10-2017, 12:19 PM
Last Post: TommiePuglet
  Abs sensors? Matt 10 6,696 05-07-2017, 09:21 AM
Last Post: Matt
