Fog light bulb help
Fog light bulb help
My fog lights aren't working ( D shape )but are showing up on the dash and relay is clicking so I took a bulb out and it's a h1. The Haynes manual says h3. Is there a difference between these bulbs and is that why there not working. If not could it be blown and I can replace it with either h1 or h3
Also I attached it to a battery and nothing happens. Tried a h4 that I had handy and that worked so could be the bulb it's self but still not sure what to replace it with
NO SMOKE NO POKEBig Grin
The P2 and P3 fog lights use H1 bulbs. Change those and you will be away.
Its only the P1's that use H3's
HDi Cabby Project Click
(28-04-2013, 12:11 PM)londondan86 Wrote: The P2 and P3 fog lights use H1 bulbs. Change those and you will be away.
Thanks. Just come back from Halfords now and stuck some xenon h1's in and they work now. Not bad for £3. Done the fog light flash mod and realised the fog bulbs didn't work. Ha
Just as info, i had H1's fitted to mine, i uprated the bulbs to 100w H1 Xenons. I had to uprate the fuse also the standard one blew.
1999 2.0 8v Turbo 306
You Tube: 832 Performance
(13-05-2013, 02:01 PM)PUGNUT_XS Wrote: Just as info, i had H1's fitted to mine, i uprated the bulbs to 100w H1 Xenons. I had to uprate the fuse also the standard one blew.
Not sure that was a wise move. 100W bulbs will require uprating the wiring as well, what you have done is just bypassed the part which is blowing as the circuit is not up to the current demand. Also they are illegal for road use.
A good set of halogens/zenons are just as good!
Just got 6k h7r's for my low beam might get some 3k or 4k for my fogs.
Yea I've got 6k's in my angels and some cheapo blue zenons in the fogs, I may well do the same and get some Hid's for them
The only issue may be that I have my fogs set up with the flash mod and Hid's don't react as quick as halogens
(14-05-2013, 09:01 PM)londondan86 Wrote: Yea I've got 6k's in my angels and some cheapo blue zenons in the fogs, I may well do the same and get some Hid's for them
Ye I've got the flash mod and was wondering about that aswell
  Fog lights, new bulb ROBCAT 0 1,439 14-06-2018, 09:11 PM
Last Post: ROBCAT
  Ph1 replacing dual bulb headlight assembly with a single bulb H4 one The Coolest 9 2,704 13-11-2015, 04:48 PM
Last Post: The Coolest
  Odd Bulb Issue... Toms306 20 4,228 04-10-2014, 02:18 PM
Last Post: Connor
