Cable Runs
Cable Runs
I know its something thats been covered loads before but are there any places in the bulkhead that are easy to get cables through without drilling new holes?
Im after one to push a couple of small cables through on the drivers side atm will probably drill a hole for the amp cable on the pass side later on.
This is for a gti with ac btw Smile
Right up by the master cylinder there's a grommet. Just poke it through and there's a hole that comes out behind the clocks.
That the same one the throttle cable runs through or separate?
Separate one mate
Got a picture ? Can't find it must just be being thick
Its tucked right up at the top, need to get your head down by the slam panel to see it
Personally I just Make a hole down behind the battery with a hole saw, cut bit of pipe and slide longwise to put around the sharp edges, and then you can run whatever you want in, and comes out right behind the glovebox Smile
[Image: sigi-2.png]
[Image: IMG_20121229_113506-1.jpg]
