Cable Runs - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: Cable Runs (/showthread.php?tid=13553) |
Cable Runs - rocker8742 - 05-05-2013 I know its something thats been covered loads before but are there any places in the bulkhead that are easy to get cables through without drilling new holes? Im after one to push a couple of small cables through on the drivers side atm will probably drill a hole for the amp cable on the pass side later on. This is for a gti with ac btw
RE: Cable Runs - Jonny81191 - 05-05-2013 Right up by the master cylinder there's a grommet. Just poke it through and there's a hole that comes out behind the clocks. Re: Cable Runs - rocker8742 - 05-05-2013 That the same one the throttle cable runs through or separate? RE: Cable Runs - Jonny81191 - 05-05-2013 Separate one mate Re: Cable Runs - rocker8742 - 06-05-2013 Got a picture ? Can't find it must just be being thick RE: Cable Runs - Slam Wagon - 06-05-2013 Its tucked right up at the top, need to get your head down by the slam panel to see it RE: Cable Runs - darrenjlobb - 06-05-2013 Personally I just Make a hole down behind the battery with a hole saw, cut bit of pipe and slide longwise to put around the sharp edges, and then you can run whatever you want in, and comes out right behind the glovebox
RE: Cable Runs - Eeyore - 06-05-2013
