Threads: 36
Car Model/Spec: GTI6 with XUD
ive kept taking the hs fuse in and out and nothing was happening also bent all the individual clamps together to make a better connection and its still the same . were u taking the hs fuse out while the engine was runing ???
Threads: 29
Car Model/Spec: ph1 sigma d turbo!!
I had the clocks out mate and no the car was off i just kept fiddling around with it till the central locking was locking its self , which one did you take out the one in the engine bay or the fues box one? I kept fiddling with it up and down takin one pin out and just messing around because i was confused.com i know it sounds silly but it worked
Threads: 36
i kept fidling with the hs fuse with no rating in the fuse box in the car
Threads: 36
couldn't hear no interference, no i haven't where are the grounds, yeah the door loom is fine elecy windows and mirrors work cheers
Threads: 6
Hi, i'm having the exact same problems with my clocks. Did anybody ever find a fix?
