24-04-2013, 12:40 PM
Tryin to take the whole air filter box out to do bit of work bit don't wanna break anything, is there any bolts I should know bout hidden away holding it in?
Air box question
24-04-2013, 12:42 PM
You'll probably break the plastic clip things at the front of the box, they locate in a bracket under the slam panel.
Apart from that, there's just the nut (or is a bolt, cant remember) at the back of the airbox, coming from the battery box.
Nope, the whole thing is held by one nut at the back and two locating pins at the front.
Take care not to loose the captive bolt at the back when removing the box. (24-04-2013, 12:42 PM)Toms306 Wrote: You'll probably break the plastic clip things at the front of the box, they locate in a bracket under the slam panel. If you rotate forward then pull up you shouldn't break the plastic pins.
24-04-2013, 12:53 PM
As DeeTurbo says.
Mike, no offence, but please tell me you're not drilling holes in it or something similarly daft..?
24-04-2013, 01:14 PM
No mate taking it out to clean a bit of engine
24-04-2013, 05:01 PM
(24-04-2013, 12:42 PM)Toms306 Wrote: You'll probably break the plastic clip things at the front of the box, they locate in a bracket under the slam panel. If you rotate forward then pull up you shouldn't break the plastic pins. [/quote] I haven't broken any yet lol, seen several broken though, especially at scrappys.
24-04-2013, 05:46 PM
Ah gotcha, fair play, that's a relief haha!
