Air box question - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Air box question (/showthread.php?tid=13158) |
Air box question - MIKE-FORD - 24-04-2013 Tryin to take the whole air filter box out to do bit of work bit don't wanna break anything, is there any bolts I should know bout hidden away holding it in? RE: Air box question - Toms306 - 24-04-2013 You'll probably break the plastic clip things at the front of the box, they locate in a bracket under the slam panel. Apart from that, there's just the nut (or is a bolt, cant remember) at the back of the airbox, coming from the battery box. RE: Air box question - DeeTurbo - 24-04-2013 Nope, the whole thing is held by one nut at the back and two locating pins at the front. Take care not to loose the captive bolt at the back when removing the box. (24-04-2013, 12:42 PM)Toms306 Wrote: You'll probably break the plastic clip things at the front of the box, they locate in a bracket under the slam panel. If you rotate forward then pull up you shouldn't break the plastic pins. RE: Air box question - Poodle - 24-04-2013 As DeeTurbo says. Mike, no offence, but please tell me you're not drilling holes in it or something similarly daft..? RE: Air box question - MIKE-FORD - 24-04-2013 No mate taking it out to clean a bit of engine RE: Air box question - Toms306 - 24-04-2013 (24-04-2013, 12:42 PM)Toms306 Wrote: You'll probably break the plastic clip things at the front of the box, they locate in a bracket under the slam panel. If you rotate forward then pull up you shouldn't break the plastic pins. [/quote] I haven't broken any yet lol, seen several broken though, especially at scrappys. RE: Air box question - Poodle - 24-04-2013 Ah gotcha, fair play, that's a relief haha!
