Gauges
Gauges
Hey all im fitting an oil pressure gauge to my car and need to no where the sender unit goes ie into the block where the old oil pressue gauge sender unit is its a v reg 1.6 phase 3
Any help would be great
Thanks craig
you can use a sandwich plate that goes between the oil filter and block
http://www.ebay.co.uk/itm/Oil-Filter-San...337c2a9ae2
Oki cheers
Here is a few pics basically the green plug is the one that I think needs to come out and be replaced by the new sender unit
You will most probably need an adaptor to fit it in there, the sender will probably be 1/8 NPT, not sure what the original thread is. Easier to get a sandwich plate.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Cheers ricky will look into getting one
