Gauges - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: TU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=18) +--- Thread: Gauges (/showthread.php?tid=13067) |
Gauges - bighead02 - 21-04-2013 Hey all im fitting an oil pressure gauge to my car and need to no where the sender unit goes ie into the block where the old oil pressue gauge sender unit is its a v reg 1.6 phase 3 Any help would be great Thanks craig RE: Gauges - zx_volcane - 21-04-2013 you can use a sandwich plate that goes between the oil filter and block http://www.ebay.co.uk/itm/Oil-Filter-Sandwich-Plate-Universal-fit-Gauge-Sender-/221126499042?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item337c2a9ae2 RE: Gauges - bighead02 - 21-04-2013 Oki cheers RE: Gauges - bighead02 - 21-04-2013 Here is a few pics basically the green plug is the one that I think needs to come out and be replaced by the new sender unit RE: Gauges - Ricky - 21-04-2013 You will most probably need an adaptor to fit it in there, the sender will probably be 1/8 NPT, not sure what the original thread is. Easier to get a sandwich plate. RE: Gauges - bighead02 - 21-04-2013 Cheers ricky will look into getting one |
