File Line Function
/global.php 961 eval
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
/showthread.php 1651 eval
Hdi leaking fluid
Right I have a leak of some sort it's not oil as its bit black it's kinda clear as far as I can make out.
its coming from the engine bay area but all my fluid levels seem ok, it's a funky smelling fluid, I can only think if either brake fluid or power steering fluid or gearbox ??
I can't see where it's coming from. The car is very low and ive buckled a few bolts that hang low could I have cAught a pipe ?? Or punctured something metal any ideas welcome as I just can't see anything :-(
This can be removed by admin had a little look and it looks like a gearbox leak :-(
If its gearbox good chance it will be drive shaft oil seals
Is not black? Gearbox oil will be black and stinks of fish!
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
It's leaking from passenger drive shaft seal its a tiny of green/ black
You would know if it's gearbox oil, f*cking rank stuff!
Place a bit of cardboard under the bay?
Is it after a run or all the time?
306 HDI, soon to be XUD
Gearbox oil smells like celery
Slowly leaks all the time it looks clear but had a slight greeny yellow tinge to it and yep it stinks and doesn't taste very nice :-( got a mouth full when I prodded the rubber seal on the driveshaft it's loose and looks like that's here it's coming from
Think the seals are about a tenner each and are an easy job
Worth getting both done and fluid changed or just fix what's broke Undecided
May as well do both and change all the oil
