Hdi leaking fluid - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Hdi leaking fluid (/showthread.php?tid=12402) |
Hdi leaking fluid - Jukie88 - 31-03-2013 Right I have a leak of some sort it's not oil as its bit black it's kinda clear as far as I can make out. its coming from the engine bay area but all my fluid levels seem ok, it's a funky smelling fluid, I can only think if either brake fluid or power steering fluid or gearbox ?? I can't see where it's coming from. The car is very low and ive buckled a few bolts that hang low could I have cAught a pipe ?? Or punctured something metal any ideas welcome as I just can't see anything :-( Hdi leaking fluid - Jukie88 - 31-03-2013 This can be removed by admin had a little look and it looks like a gearbox leak :-( RE: Hdi leaking fluid - Frosty - 31-03-2013 If its gearbox good chance it will be drive shaft oil seals RE: Hdi leaking fluid - C2K - 31-03-2013 Is not black? Gearbox oil will be black and stinks of fish! Hdi leaking fluid - Jukie88 - 31-03-2013 It's leaking from passenger drive shaft seal its a tiny of green/ black RE: Hdi leaking fluid - declantg - 31-03-2013 You would know if it's gearbox oil, f*cking rank stuff! Place a bit of cardboard under the bay? Is it after a run or all the time? RE: Hdi leaking fluid - Oil-burner - 31-03-2013 Gearbox oil smells like celery Hdi leaking fluid - Jukie88 - 31-03-2013 Slowly leaks all the time it looks clear but had a slight greeny yellow tinge to it and yep it stinks and doesn't taste very nice :-( got a mouth full when I prodded the rubber seal on the driveshaft it's loose and looks like that's here it's coming from RE: Hdi leaking fluid - Oil-burner - 31-03-2013 Think the seals are about a tenner each and are an easy job Hdi leaking fluid - Jukie88 - 31-03-2013 Worth getting both done and fluid changed or just fix what's broke ![]() Hdi leaking fluid - Frosty - 31-03-2013 May as well do both and change all the oil |
